Setting multiple interrupt bits and global at same time.
future
PostPosted: Sat Jun 26, 2004 11:43 am     Reply with quote
Is there any problem?
like:
enable_interrupts(int_ext|int_timer0|global);
PostPosted: Sat Jun 26, 2004 12:02 pm     Reply with quote
It won't work. If you look at the .H file for your PIC,
you'll see that the INT_xxx definitions consist of the
register address in the high byte and a bitmask in
the lower byte.
If you OR together different constants, you could
destroy the register address. If you OR together
different bitmasks, the compiler will only use the
first '1' bit that it finds. It will ignore the others.
In short, the compiler is not designed to allow
multiple INT_xxx constants to be OR'ed together.
future
PostPosted: Sat Jun 26, 2004 12:43 pm     Reply with quote
I tried that with a 18f452.
#byte INTCON = 0xFF2
Generated code:
....................enable_interrupts(int_ext|int_timer0|global);
084A: MOVLW F0
084C: IORWF FF2,F
F0=11110000 // sets GIE,PIE,TMR0IE,INT0IE
And works Smile
But I dont know if I should set GIE and another int at the same.
PostPosted: Sat Jun 26, 2004 2:54 pm     Reply with quote
Before I posted, I did a test with the 16F877 and PCM 3.190
and it didn't work.
ckielstra
PostPosted: Sat Jun 26, 2004 4:02 pm     Reply with quote
I guess Future was lucky in choosing his combination of interrupts.
For the 18F452:
#define GLOBAL                    0xF2C0
#define INT_RTCC                  0xF220
#define INT_TIMER0                0xF220
#define INT_TIMER1                0x9D01
#define INT_TIMER2                0x9D02
#define INT_TIMER3                0xA002
#define INT_EXT                   0xF210
It only works because GLOBAL, RTCC and INT_EXT are all in the same register. Replacing INT_TIMER0 by INT_TIMER1 would have resulted in disaster.
I personally disagree off using undocumented features like this because it might result to hard to find bugs in the future, for example when upgrading to a new compiler version or other chip. You have to consider if this future trouble is worth the 4 bytes you save now.
