Newbie
Goto page Previous  1, 2
Joan
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Re: RE:
PostPosted: Fri Jun 25, 2004 6:16 am     Reply with quote
Joan wrote:
HI, Joan
B) A more acurate solution is to use 3 Timers with their interrupts, but in your case this solution is not possible because F628 doesn't have 3 Timers interrupts, it only have Timer0 interrupt.
I correct 2 errors:
1.- 16F628 have 3 timers (timer0, timer1, timer2) ... then you can blink each LED with each Timer. But I think the best solution is to do all with timer0.
2.- Inside the isr routine you must increment Counter variable and interchange LED_A for LED_C if led blinking rates aren't correct.
Best Regards;
Joan Idea
I Came. I Saw. I Won.
iou_82
RE: Blinking LED
PostPosted: Wed Jun 30, 2004 10:47 pm     Reply with quote
Joan,
Thanks for the tips but i still cannot get it done.
I have some trouble with the code. it say no isr_timer0
what does that mean? As I am still a beginner i dun really understand that.
Thank you
Best Regards
Eugene
Joan
Re: RE: Blinking LED
PostPosted: Thu Jul 01, 2004 2:36 am     Reply with quote
iou_82 wrote:
Joan,
Thank you
Best Regards
Eugene
Eugene:
are you declaring the isr correctly ? I think this is a simple problem ... look in the examples suplied with your CCS Compiler how is it declared ...
Best Regards;
Joan Idea
Page 2 of 2
