ksplem Guest
| ICD-U - Test Target error |
Posted: Sat May 29, 2004 4:39 am |
I just hooked up a CCS software proto-board, my new ICD-U40 and a PIC18F448 into the board. I don't think it matters but the PIC18F448 is from Digikey since the kit didn't come with one even though I asked.
I wrote a quick & simple test program and then tried to compile, download and then run it. It compiles...
The 'ICD Control Program' doesn't seem to download and so I hit 'Test Target' and here is the message box.
ICD Error
Unknown PIC18 device, ID: 0101 if this is a valid id, then make sure the algorithm inside chipedit is set correctly.
OK
I have green lights on for board power and ICD-U40.
How do I get around this or download the algorithm?
Thanks for any help! |
ksplem Guest
| Re: ICD-U - Test Target error |
Posted: Sat May 29, 2004 5:01 am |
It just started working, perhaps I'm a dope!
I resinstalled MPLAB and then hit proto-board reset and then the chip was detected and I seem to be running. Sorry for the post litter!
| ksplem wrote: | Hi,
ICD Error
OK
