Inverting the state of an output pin
Future
PostPosted: Thu May 13, 2004 10:16 pm     Reply with quote
Hi, I moved from Basic to C and I'm having a little trouble...
I have this code:
#int_TIMER0
TIMER0_isr() {
   if(mms=10) {
      ms++;
      mms=0;
      read_adc(ADC_START_ONLY);
      if(ms=10) {
         tenth++;
         ms=0;
         if(tenth=10) {
            sec++;
            tenth=0;
            if(!input(PIN_C4)) output_high(PIN_C4);
               else output_low(PIN_C4);
I want it to invert the state of portc.4 every second, but it is always on.
Does someone can help me?
Thank you.
Haplo
PostPosted: Thu May 13, 2004 11:06 pm     Reply with quote
The equality check in C is ==, so change your 'if' statements to
if(mms==10)
and so forth.
ckielstra
PostPosted: Fri May 14, 2004 12:14 am     Reply with quote
and more efficient is to use the function output_toggle(PIN_C4).
PostPosted: Fri May 14, 2004 4:43 am     Reply with quote
very weird if I put if(mms==10) it doesn't light at all.
with if(mms=10) it takes one second to light but stays always on.
PostPosted: Fri May 14, 2004 5:00 am     Reply with quote
Hmm the problem was mine..
TIMER0_isr() {
if(mms=10) {
ms++;
mms=0;
has to be
TIMER0_isr() {
mms++;
if(mms=10) {
ms++;
mms=0;
good to see the fast replies. thank you very much.
Haplo
PostPosted: Fri May 14, 2004 5:04 am     Reply with quote
TIMER0_isr() {
if(mms=10) {
ms++;
mms=0;
has to be
TIMER0_isr() {
mms++;
if(mms=10) {
ms++;
mms=0;
You are still using a single = for equality check. That 'if' statement has no effect.
PostPosted: Fri May 14, 2004 7:36 am     Reply with quote
Just a single copy/paste from the forum. In my code it is already fixed.
Thank you.
