HELP!!a little more!!!
drzxoulis
PostPosted: Fri Apr 16, 2004 10:08 pm     Reply with quote
Is any possible way i could really make the expression below look simpler without loosing its functionality.?????
if (temp>80)
printf(lcd_putc,"\fPRESSURE:%4.0f mB\nHIGH TEMP",pres);
else if (temp<-20)
printf(lcd_putc,"\fPRESSURE:%4.0f mB\nLOW TEMP",pres);
else if (pres<500)
printf(lcd_putc,"\fLOW PRESSURE\nTEMP:%2.1f %CC",temp,0xDF);
else if (pres>1150)
printf(lcd_putc,"\fHIGH PRESSURE\nTEMP:%2.1f %CC",temp,0xDF);
else if (temp>80 && PRES<500)
lcd_putc("\fLOW PRESSURE\nHIGH TEMP");
else if (temp<-20 && PRES<500)
lcd_putc("\fLOW PRESSURE\nLOW TEMP");
else if (temp<-20 && PRES>1150)
lcd_putc("\fHIGH PRESSURE\nLOW TEMP");
else if (temp>80 && PRES>1150)
lcd_putc("\fHIGH PRESSURE\nHIGH TEMP");
printf(lcd_putc,"\fPRESSURE:%4.0f mB\nTEMP:%2.1f %CC",pres,temp,0xDF);
Any suggestion more than welcomed!!!!!Thanks in advance.......
Haplo
PostPosted: Sat Apr 17, 2004 1:53 am     Reply with quote
Are you sure you want to maintain the functionality of that code? Because I don't think it works properly as it is. You have overlapping conditions but they can't run together. For example if temp=100 and PRES=100, what do you want the code to print? Right now it will execute the line printf(lcd_putc,"\fPRESSURE:%4.0f mB\nHIGH TEMP",pres); but you also have another condition check to execute lcd_putc("\fLOW PRESSURE\nHIGH TEMP");, and this line will never run because the code flow will never get to this point.
drzxoulis
PostPosted: Sat Apr 17, 2004 7:29 am     Reply with quote
As you said the whole loop doesn't really work.
what i want to achieve is just a way of presenting the limits on the lcd.
this means having for each limit something writen eg."low temp" and silmutaneously the result from the other.
But for some reason it doesn't work if i want to have both warnings on the lcd.
Any ideas?
Humberto
PostPosted: Sat Apr 17, 2004 8:06 am     Reply with quote
drzxoulis,
I suggest the following:
1) Reserve the upper line of the LCD to display PRESURE values,
2) Reserve the lower line to display TEMP values.
printf(lcd_putc,"\f"); // Clear the LCD display ONCE
if (pres<500)
   printf(lcd_putc,"LOW PRESSURE !");
else if (pres>1150)
   printf(lcd_putc,"HIGH PRESSURE !");
   printf(lcd_putc,"PRESSURE:%4.0f mB",pres);
if (temp>80)
   printf(lcd_putc,"\nHIGH TEMP !");
else if (temp<-20)
   printf(lcd_putc,"\nLOW TEMP !");
   printf(lcd_putc,"\nTEMP:%2.1f %CC",temp,0xDF);
Easy isnīt ???
Humberto
