16f877 hangs up in ISR (RDA)
Fabian
PostPosted: Fri Apr 16, 2004 12:44 am     Reply with quote
The programm shall output on Port b when the input is > 0.
This works only for the first time and then the pic hangs itself up.
#include <16F877.h>
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#define buffer_SIZE 10
BYTE buffer[buffer_SIZE]={0};
BYTE tail = 0;
BYTE receivedFrame = 0;
BYTE T1;
BYTE T2;
BYTE T3;
BYTE L1;
BYTE L2;
BYTE L3;
BYTE A1;
BYTE A2;
BYTE A3;
#INT_RDA
void serial_isr()
  buffer[tail] = getc();
     if(buffer[tail] == '\r' || tail == (buffer_SIZE - 1))
       receivedFrame = 1;
       disable_interrupts(int_rda); //disable???
       disable_interrupts(global);  //test CCS
       printf("\n\r...Interrupts disabled...");
     } //end if
       tail++;
     } //end else
} //end serial_isr()
void message_handler()
int i;
T1=buffer[0];
T2=buffer[1];
T3=buffer[3];
L1=buffer[4];
L2=buffer[5];
L3=buffer[6];
A1=buffer[7];
A2=buffer[8];
A3=buffer[9];
   if(T1>'0') output_high(PIN_B0);
   if(T2>'0') output_high(PIN_B1);
   if(T3>'0') output_high(PIN_B2);
   if(L1>'0') output_high(PIN_B3);
   if(L2>'0') output_high(PIN_B4);
   if(L3>'0') output_high(PIN_B5);
   if(A1>'0') output_high(PIN_B6);
   if(A2>'0') output_high(PIN_B7);
for(i=0;i<BUFFER_SIZE-1;i++) buffer[i]=0;
printf("\n\r...message_handler ended...");
} //end meassage_handler()
  BYTE head = 0;
  enable_interrupts(global);
  enable_interrupts(int_rda);
  while (TRUE)
    if(receivedFrame == 1)
//      while(head != tail){
//        putc(buffer[head++]);
      puts(buffer);
      message_handler();
      delay_ms(2500);
      OUTPUT_B(0x00);
      head = tail = 0;
      receivedFrame = 0;
      enabel_interrupts(global);
    } // end if
  } // end while true
}// end main
RKnapp
PostPosted: Fri Apr 16, 2004 2:20 am     Reply with quote
There are several things that look suspicious to me:
This won't clear the entire buffer out, so the final character might still be the \r, thus the second pass would always be short by one character.
This doesn't look like a crash scenario, however.
Actually, this won't compile, right? enabel_interrupts() I don't think will fly. Therefore, perhaps in the compile-ready version, there might be more clues.
Good luck,
Smile Robert
