Problems with timer1
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Apr 15, 2004 1:52 am     Reply with quote
Timer 0 and Timer 1
my program have a Timer clock and a keypad
and have problems with timer 1 to read the Keypad.
16F877
#int_timer0
timer0_isr()
   clock -= 256;
   if (clock<256) //<256
      //seconds++;
      clock += CLOCK_VAL;
      tick = 1;
#int_timer1
timer1_isr()
  // Decrement any timers that are running.
if(gc_buttons_timer)
   gc_buttons_timer--;
void check_buttons(void)
char gc_old_button_status;
   return;
  gc_buttons_timer = BUTTONS_TIMER_TICKS;
       keyb=kbd_getc();
        if(keyb!=0)
        printf("A tecla é: %c\r\n",keyb);
        printf(lcd_putc,"\nNum-%02c ",keyb);;
        }     // Read the buttons
main()
   int conta;
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64); //
   setup_timer_1( T1_INTERNAL | T1_DIV_BY_1 );
   enable_interrupts(int_timer0); // Enable timer0 interrupt
   enable_interrupts(int_timer1);
   enable_interrupts(GLOBAL);     // Enable global interrupts
      if (tick)
         tick=0;
         //lcd_gotoxy(1,1);
         //printf(lcd_putc,"%02u",seconds);
         update_clock();
         seconds++;
          check_buttons();
Re: Problems with timer1
PostPosted: Thu Apr 15, 2004 2:20 am     Reply with quote
carlosma wrote:
Timer 0 and Timer 1
16F877
#int_timer0
timer0_isr()
   clock -= 256;
      //seconds++;
      clock += CLOCK_VAL;
      tick = 1;
#int_timer1
timer1_isr()
   gc_buttons_timer--;
   return;
       keyb=kbd_getc();
        if(keyb!=0)
main()
   int conta;
      if (tick)
         tick=0;
         //lcd_gotoxy(1,1);
         update_clock();
         seconds++;
          check_buttons();
It would help if you actually said what the 'problems' were. The listing, does not contain enough of the code to show how the system works....
Some obvious comments though do apply.
You declare a variable 'gc_old_button_status', locally inside a routine. This is not used in the code shown, but is presumably used to hold the 'old' key pattern, so that you can check for changes?. If so, this _must_ be 'static'. Otherwise it's contents may be lost between calls to the routine...
You don't show the 'update clock' function you call.
Remember that the variable 'clock', must be a 'long'.
As shown, the code will not use the 'gc_buttons_timer' to control the keyboard scan. Remember that a 'if', or an 'else', executes just the next 'statement'. You have seven lines of code in the area that is presumably meant to be the 'else', but only the first will be executed as the 'else' condition. The rest will be executed on each call. The stuff that is meant to comprise the 'else' statement, should be bracketted {} to turn it into a single functional statement.
