10 bit a/d
Goto page 1, 2  Next
drzxoulis
10 bit a/d
PostPosted: Mon Apr 12, 2004 9:17 pm     Reply with quote
Is there anyone around knowing how to read a 10 bit a/d input from my PIC16F876. I want to read an input voltage and need a resolution of 1024.I have looked around and it has to do with the 8 bit representation of the pic. If you want the code please let me know!!!
Haplo
PostPosted: Mon Apr 12, 2004 9:24 pm     Reply with quote
First of all, make sure you have this line in your code:
#device adc=10
Then, you can read a 10-bit value like this:
int16 ADC;
ADC=read_adc();
drzxoulis
PostPosted: Mon Apr 12, 2004 9:27 pm     Reply with quote
is that simple???I was looking around and they said something about ADRESH and ADRESL and got kind of worried........I will try and see.....thank you for now!!!!
Haplo
PostPosted: Mon Apr 12, 2004 9:32 pm     Reply with quote
Yes it is simple. Remember, the setup_adc_ports() and setup_adc() functions need to be called (once) to setup the module prior to reading the A/D port. You can use the set_adc_channel() function to change the A/D channel.
And make sure your variable is int16, not int.
For more information, take a look at the ex_admm.c file in the \Examples directory.
drzxoulis
PostPosted: Mon Apr 12, 2004 9:42 pm     Reply with quote
i just checked it....it is not working ....this is the code...if you have any comments let me know...it is based on the EX_ADMM file...but it doesnt give the proper resolution i want....10 bits.
Haplo
PostPosted: Mon Apr 12, 2004 9:52 pm     Reply with quote
Do you have the #device adc=10 line? Is the variable you are using to read the A/D defined as int16?
Post your code.
drzxoulis
PostPosted: Mon Apr 12, 2004 9:55 pm     Reply with quote
oopppsss...forgot to do it in the previews message...anyway thats the code
#include <16F876.h>
#define PIC16F876 ADC = 10
#FUSES XT,NOWDT,NOPROTECT,NOLVP,PUT,NOBROWNOUT
#use delay (clock=20000000)
#include <LCDDRIVER.h>
#include <math.h>
int i,min,max;
long value;
//unsigned int ADRESULT ;
lcd_putc("\fA/D Converter\nWARMING UP...");
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do {
min=1023;
max=0;
//for(i=0;i<=30;++i) {
value = Read_ADC();
// ADRESULT = ADRESL;
//if(value<min)
// min=value;
//if(value>max)
//max=value;
printf(lcd_putc, "\fA/D Input Vals\nMin: %4ld",value);
//printf(lcd_putc, "\fA/D Input Vals\nMin: %3U",ADRESULT);
} while (TRUE);
Haplo
PostPosted: Mon Apr 12, 2004 10:20 pm     Reply with quote
How do you know you are not getting the correct precision? What is the value you get back from Read_ADC() ?
Quoting from the datasheet:
When the device frequencies are greater than 1 MHz, the RC A/D conversion clock source is only recommended
for SLEEP operation.
Change your code to setup_adc(ADC_CLOCK_DIV_32);
And remember, in CCS the data type int is the same as int8. So 'min' in your code is a byte, and the line 'min=1023' will not work properly.
drzxoulis
PostPosted: Tue Apr 13, 2004 7:10 am     Reply with quote
Arrow Even doing all the above I still get a maximum of 255 samples on the LCD screen. Regarding what is in page 117 of the manual about how the values obtained from the a/d are stored on the pics memory i thing a different approach should be taken...Any suggestions? Rolling Eyes
PostPosted: Tue Apr 13, 2004 8:26 am     Reply with quote
Haplo told you this:
#device adc=10
But you did this. There is a difference.
drzxoulis
PostPosted: Tue Apr 13, 2004 9:54 am     Reply with quote
If i am not mistaken is the same thing the only i do extra is also making sure to define the pic.but the ADC=10 is defined.Anyway you stillhave to use the ADRESL and ADRESH registers.this is the working code i figured it out. thanks for any help!!
#include <16F876.h>
#use delay (clock=4000000)
#include <math.h>
#BYTE ADRESH = 0x1E // ADRESH memory address for high bits
#BYTE ADRESL = 0x9E // ADRESL memory address for low bits
//ADMF is set to 0 by default.Check the pic manual for it.
int i,min,max,value;
unsigned long RESULT ;
do {
delay_ms(100);//time for capacitor to charge up
value = Read_ADC();//read proper channel
min=ADRESL; //get values
max=ADRESH; //get values from registers
RESULT = ADRESH; //give 8 first bits in result
RESULT=(RESULT <<2 | min >>6);//take those shiftthem
//positions and OR them by
//value of min shifted 6 pos
printf(lcd_putc,"\fmin:%3U max:%3U\nVAL:%3U RES:
4ld",min,max,value,RESULT);
} while (1);
PostPosted: Tue Apr 13, 2004 10:33 am     Reply with quote
In electronics, one of the most important things is attention to detail.
That's all I have to say.
languer
PostPosted: Tue Apr 13, 2004 12:46 pm     Reply with quote
Three things I want to point out:
    1. What are you expecting out of 'value', since you now declared it as a int8?
    2. You do notice that you were printing with the 'signed decimal long' modifier (%ld).
    3. Although I have never had a problem with the read_adc() function as is, you can also use the make16() to join ADRESH and ADRESL also.
drzxoulis
PostPosted: Tue Apr 13, 2004 1:30 pm     Reply with quote
Exclamation languer thanks for the remarks
First of all i left value like that because i am not going to use it after all.
Being new to the thing i don't see a problem printing with %ld. i get the exact output i want and is very very accurate too. i have never used make16 before but i will take a look in it. Have you ever used read_adc for 10 bit output???
And it is not possible to compile with #device adc = 10 as some stated previously.
with the code i sent and a few mods i can read from like 5 analog inputs and have great accuracy......any suggestion welcomed......not comments ending in "thats all i have to say". Shocked
PostPosted: Tue Apr 13, 2004 2:00 pm     Reply with quote
any suggestion welcomed......not comments ending in "thats all i have to say" Shocked .
The reason I made that comment is because Haplo showed you
how to use the #device adc=10 statement.
You then changed it to #define which is a completely different
word, and it won't work.
Then you said this:
But of course, that is not what Haplo posted. You have added spaces
before and after the '=' symbol. It will not compile if you add those
spaces.
Also, the statement must be placed on the next line after the main
include statement. Like this:
#include <16F877.h>
#device adc=10
The basic problem is that you don't follow instructions very well,
so it's very difficult to give you any help.
Goto page 1, 2  Next
Page 1 of 2
