Help needed: int or int8 doesn't compare < 0 correctly?
djpark
PostPosted: Thu Apr 08, 2004 9:02 pm     Reply with quote
I am desperately seeking help for the code below using PCM 3.188 for 16F648A.
When i becomes negative (-127 ~ -1) I intend to add MAX_INDEX, but that part of the code is not executed and from the asm/list below, it doesn't seem to be compiled in at all.
Am I missing something such as the way how to declare a signed int variable or PCM has a bug?
-- dj
#separate
int8 get_index(int t)
   int8 i;
   i = rf_index - t + 1;
   if (i < 0)
      i += MAX_INDEX;
   return i;
0000                02473 .................... #separate
0000                02474 .................... int8 get_index(int t)
0000                02475 .................... {
0000                02476 ....................    int8 i;
0000                02477 ....................
0000                02478 ....................    i = rf_index - t + 1;
071B 087E       02479 MOVF   7E,W
071C 0261       02480 SUBWF  61,W
071D 3E01       02481 ADDLW  01
071E 1683       02482 BSF    03.5
071F 00A0       02483 MOVWF  20
0000                02484 ....................    if (i < 0)
0000                02485 ....................    {
0000                02486 ....................       i += MAX_INDEX;
0000                02487 ....................    }
0000                02488 ....................    return i;
0720 0820       02489 MOVF   20,W
0721 00F8       02490 MOVWF  78
0000                02491 .................... }
0722 1283       02492 BCF    03.5
0723 118A       02493 BCF    0A.3
0724 2F28       02494 GOTO   728 (RETURN)
PostPosted: Thu Apr 08, 2004 9:33 pm     Reply with quote
The problem is that older versions of the CCS manual had this
vital sentence in them:
All types, except float, by default are unsigned; however,
they may be preceded by 'unsigned' or 'signed'.
Recent versions do not have it. I have emailed CCS about the
importance of putting that sentence back in, but they haven't
done it yet.
To declare a variable as signed, you have to do this:
signed int8 value;
djpark
PostPosted: Thu Apr 08, 2004 9:47 pm     Reply with quote
signed int8 value;
Thanks a lot for the quick reply.
How strange CCS handles the default. From other C programming experience, I never expected that int default to unsigned int.
Till I got your answer, I had to use bit_test to check the sign bit.
        //if (i < 0)
        if (bit_test(i, 7))
Now I am back to the normal comparison syntax, thanks to you!
-- dj
