PIC181220/1320 40Mhz
NikkiC
PostPosted: Thu Apr 08, 2004 10:42 am     Reply with quote
I've have attempted to use the H4 mode to run PIC18F1220/1320 at 40 Mhz. The clock is totally unstable. I've tried a few chips. I've never had a problem with PIC18F252/452.
I'm using PCH 3.170. Does anyone know if this is a problem specific to earlier versions of the compiler? I'm trying to rule out a hardware issue.
Thanks,
Nikki
|Raph|
PostPosted: Thu Apr 08, 2004 10:48 am     Reply with quote
We are using CCS v3.188 here and we tried it on many 18LF1320 with no success.
Neutone
PostPosted: Thu Apr 08, 2004 11:51 am     Reply with quote
To run at 40Mhz the supply voltage must be greater than 4.2V. Also to change from the HS to 4xHS you have to cycly power after programming. Nikki I assume that your 10Mhz crystle works without the 4xHS setting?
PostPosted: Thu Apr 08, 2004 12:37 pm     Reply with quote
Yes, it is definitely running at 5V.
The cycling off power goes without saying as I'm manually plugging the PIC into a Warp13 programmer and then back into my development board by hand.
All the PICs work with no problem at 10Mhz with
#use delay(clock=10000000)
#fuses HS, BORV20, MCLR,NOLVP,NOWDT,NOBROWNOUT
and then fail to run with any stability with
#use delay(clock=40000000)
#fuses H4, BORV20, MCLR,NOLVP,NOWDT,NOBROWNOUT
The clock fluctuates between 10Mhz and 40Mhz.
Nikki
C-H Wu
18F1320 at 40 MHz
PostPosted: Thu Apr 08, 2004 7:59 pm     Reply with quote
20 MHz ... ok.
40 MHz with 10 MHz X'tal and H4PLL, never success, with chip date code up to 0404 (4th week of 2004)
I believe it is a silicon bug.
Internal 8 MHz ... ok ... this is good, cheers.
PostPosted: Fri Apr 09, 2004 1:29 am     Reply with quote
Do you have a resistor series with crystal? Use 100-470 Ohm.
