Inerrupt for begin if any key press
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Apr 07, 2004 5:42 am     Reply with quote
Hello
I do a program to read IO and save in the Eeprom the value and this program need a 4 digit code to acces. I can change the code press *
Use LCD. C and Keyboard 4x4.
I need help to configure Inteerupt IF no key press in 5 seconds return to Begin, like a normal access code.
Thank you
Carlos
#include <16F877.h>
#USE RS232 (baud = 9600, xmit = PIN_C6, rcv = PIN_C7 )
#include <lcd.c>
#include <kbd.c>
#rom 0x2100={1,2,3,4}
void grava()
   int ncod =0;
   printf("programacao %c\r\n",k);
   lcd_putc("\fNovo Codigo\n");
   for (ncod = 0; (ncod < nmax);)
      k=kbd_getc();
      if(k!=0)
         lcd_putc("*");
         ncod++;
         write_eeprom ((ncod - 1),(k - 0x30));
   printf("Codigo gravado %c\r\n",k);
   lcd_putc("\fCodigo gravado\n");
   while (TRUE)
         k=kbd_getc();
         if(k!=0)
        if(k=='*')
           grava();
          //lcd_putc('\f');
                lcd_putc("*");
                 EE=read_eeprom(Ponta);
                rel = EE + 0x30;
                printf( "%2x ", k );
                printf( "%2x ", rel );
                n++;
                Ponta++;
                if ( (rel==k) && (correcto==(Ponta -1) ))
                  correcto++;
                      if ( n == nmax )
                     output_high(pin_b0);
                     printf("ligado %c\r\n",k);
                     lcd_putc("\fCodigo Correcto\n");
PostPosted: Wed Apr 07, 2004 12:03 pm     Reply with quote
So you need the code to timeout if there is no keypress after
a specified time. Look at my answer in this thread below.
Also look at the link at the end of the thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=18034
