HELP ON RS232 AND PIC16F877
mizi_suichiro
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Tue Mar 23, 2004 6:11 am     Reply with quote
hi, i'm blur with this microcontroller. i need to read an 8-bit data from memory buffer (external hardware) and send it through serial port into a PC. i don't know how to setup the PIC16F877 so i can transmit 8 bit data serially to the PC using Tx and Rx pin. i'm using C++ programming, but i stuck about how to send the reading 8 bit data to the PC and i can read data. (the memory buffer contains the information from the CMOS camera).
hope anyone can help me with this thing. thanks.
Haplo
PostPosted: Tue Mar 23, 2004 7:00 am     Reply with quote
You are using C++? So you are not using CCS?
If you are using CCS, you can use the #use RS232 statement to define a serial port and then communicate using the built-in functions (such as printf(), getc() and putc()). PIC16F877 has a hardware serial port on pins C6 and C7 so you can use this:
Refer to compiler manual for more information.
mizi_suichiro
PostPosted: Tue Mar 23, 2004 7:08 am     Reply with quote
i'm using CCS, and using C languange to make the microcontroller work. if i set the RS232 function like you says, so i just using function printf() to send the data to PC? is it right? can you give me a little bit example of the programming. thanks.
Haplo
PostPosted: Tue Mar 23, 2004 4:30 pm     Reply with quote
That is right. Look at the EX_SQW.C file in your \Examples directory. It explaines things pretty well.
PostPosted: Wed Mar 24, 2004 4:07 am     Reply with quote
thanks!!
