How to Reset my MCU from a RS-232 signal (DTR, etc.)
cfernandez
PostPosted: Sun Mar 21, 2004 2:32 pm     Reply with quote
I need to reset my MCU from a RS-232 signal, is possible to send me the schematics for this and sample code.
Thank you very much!!!!!
Felix Althaus
PostPosted: Sun Mar 21, 2004 2:42 pm     Reply with quote
Hi
How do you want to reset your PIC? By hardware signal or by a received RS232 command?
Can you specify your problem a little bit more?
Felix
cfernandez
PostPosted: Sun Mar 21, 2004 2:47 pm     Reply with quote
I want to reset my PIC by put the RST or other singal in RS-232 in HIGH. Not by command.
Konrad
PostPosted: Sun Mar 21, 2004 4:34 pm     Reply with quote
DTS/DTR is probably better, just connect via 22k to /MCLR, but,
What are you trying to do?
Use restart() & RS232 interrupts would probably be more controlable.
Re: How to Reset my MCU from a RS-232 signal (DTR, etc.)
PostPosted: Sun Mar 21, 2004 5:50 pm     Reply with quote
cfernandez wrote:
I implement this method thru RS232 but I send a command to the PIC using reset_cpu() method.
PostPosted: Sun Mar 21, 2004 5:51 pm     Reply with quote
I don't think CCS has a built-in function for restart()...
cfernandez
PostPosted: Sun Mar 21, 2004 8:14 pm     Reply with quote
I am making a reader to connect a POS and is possible that the POS need reset the reader, for example: The POS upgrade the firmware of reader and in the middle of upgrade the electrical conexion OFF, then the reader not have a correct firmware and is possible that the POS RESET the reader to comunicate with the bootloader.
You have a best idea for this case?
Best Regards.
Pete Smith
View user's profile Send private message Visit poster's website MSN Messenger ICQ Number
PostPosted: Mon Mar 22, 2004 3:23 am     Reply with quote
reset_cpu(); is what you're after.
HTH
Pete.
