CyberTron Guest
| Hardware UART help??!! |
Posted: Fri Apr 23, 2004 2:28 pm |
Does anyone have a code, example, or anything that could help me doing this:
I have a Pic 16f870 (same family as 16f877), and is using PCWH 3.097
My problem:
I want to use hardware uart to transmit an A/D value in a specific time range....like somewhere between 0-60 seconds...this should happen at a random time between this range...and only once..
How would I do that? I mean, I have figured out that the funktion PUTC is very useful for transmitting data through RS232,
my theory is like this:
int32 ad;
main()
poll();
void poll(void)
ad=readadc()
putc(ad);
Of course there should be more code, but is the thought correct? should that code send the a/d value all the time??
How would I do a timer?
/Friendly wishes Mike |
| Re: Hardware UART help??!! |
Posted: Fri Apr 23, 2004 3:15 pm |
| CyberTron wrote: | Does anyone have a code, example, or anything that could help me doing this:
My problem:
int32 ad;
main()
poll();
void poll(void)
ad=readadc()
putc(ad);
putc, only sends one character. You need to use 'printf'. You don't need a int32, for ad (use an int16).
Then:
printf(putc,"AD Value: %4ld/n",ad);
will send the string 'AD Value: xxx' and a line feed, where 'xxx' will be one to four digits, in text form, containing the AD value. Obviously, you don't need to add the 'descriptive' text, but you do need to add some form of seperator, if the receiver is to know where one number ends, and the next starts.
You don't say what clock rate is in use, but I'd suggest programming timer2, to interrupt at perhaps 1/100th second intervals - since you have PCW, use the Wizard to set up a timer, and look at the code it generates. It is not perfect, but will show you how the values change.
Then have a 'global' variable called something like 'time_to_send', and set the limit on the 'rand' function, like this:
RAND_MAX = 60;
Do this in the main code.
Then have an interrupt handler with something like:
#INT_TIMER2
void tick(void) {
static tick=100;
static time=60;
if (tick) --tick;
else {
tick=100;
if (time) --time;
else {
timeto_send=RND();
time=60;
if (time_to_send) --timeto_send;
Then in the main code loop with:
while (time_to_send) ;
and send the string when this drops through.
What should happen, is that 'tick' counts down on every interrupt to zero. When it reaches zero (once per second), it decrements 'time' when this reaches zero, a random value, is put into 'time_to_send'. If time_to_send is non zero, it is decremented.
In the main code, you wait till 'time_to_send' equals zero, and send the ADC value.
CyberTron Guest
Posted: Sat Apr 24, 2004 12:42 am |
Thank you for your fast reply!! :D
I will try this today and report my success or failure :D
/Mike |
CyberTron Guest
Posted: Sun Apr 25, 2004 2:37 am |
Trouble again!
I´ve done this code:
| Quote: |
#include <16f870.h>
#include <stdlib.h>
#include <stdio.h>
/* Config för PIC-processor*/
#fuses XT, NOPROTECT, NOWDT, HS
#use delay (clock=4000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
void Config(void);
void Bevakning(void);
void tick(void);
int time_to_send=0;
Config();
Bevakning();
void Config(void)
setup_adc_ports(RA0_RA1_RA3_ANALOG);
set_adc_channel(0);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
//setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,255,1);
setup_ccp1(CCP_OFF);
//enable_interrupts(INT_RDA);
enable_interrupts(global);
srand(1);
int16 ad=12;
int16 id=5;
int16 random;
float check=0;
if(time_to_send == 0) //som det är nu så skickar den 1 char/byte per
{ //gång som time_to_send = 0, dvs, den skickar I, väntar tills
ad=read_adc(); //time_to_send =0 och skickar D...osv..
check=(float)((id+ad)/2);
printf("ID:%ld AD:%ld Ch:%2f ",id, ad, check);
ad=0;
check=0;
#INT_TIMER2
void tick(void)
static int8 tick=100; //static
static int8 time=60; //static
if (tick != 0)
--tick;
tick=100;
if (time != 0)
--time;
time_to_send=rand();
time=60;
if (time_to_send !=0)
--time_to_send;
It seems to work, at least in my simulator (PIC Simulator IDE) but it doesnt look like the random funktion is working correctly?!, because it send only 1 character every 7000mikrosecond, (no random what it seem anyway), is there a faulty timer interrupt??? or is it just me ? (don't have the real stuff yet, not for another week, but does the code seem correct?)
And what can I do so it seends the whole "printf()" at the same time, (not waiting after sending 1 char??) I´ve tried
for(i=0; i<20; i++)
printf("1234567890")
i++
(not exactly like that by close) but it doesn't work
any ideas??
/Mike |
Posted: Sun Apr 25, 2004 2:51 am |
You need to set 'RAND_MAX' somewhere.
rand returns an integer, in the range 0...RAND_MAX.
I'm not sure what you mean about printf 'waiting'. Printf itself, does not 'buffer', but the hardware UART, gives a couple of characters of buffering. Printf, will send characters till the hardware buffer is full, then sit waiting, and sending each character in turn, as the buffer empties. When the function exits a couple of characters will still be in the hardware buffer, but the whole string will have 'sent' (in the sense that it will have been transferred to the hardware). If you want printf to return immediately, to allow other processing to continue, then you would need to write a soft buffered' driver, to use the serial transmit buffer empty interrupt to transfer data to the hardware.
The 'demo' code you show, should send:
1234567890123456789012345678901234567890.....
You may well have problems doing this, since the PC, could itself suffer a buffer overrun sending so much data!...
CyberTron Guest
Posted: Sun Apr 25, 2004 8:14 am |
RAND_MAX is set to 60 in STLIB.h
with commando: #define RAND_MAX 60
How would one to the Recieving part (just curious)
let's say that I want to recieve the code I just sent (see code from the other posts)...how would I do that? is it just to use getc()?
/Mike |
