Door Access Application?
chingB
PostPosted: Tue Mar 09, 2004 4:47 pm     Reply with quote
I have access application and I put a micro-switch such that when the door is open it will closed. How can I monitor the door if it is open for 20seconds it sound an alarm?
Would it be possible to use interrupt?
Thanx
asjad
Door switch
PostPosted: Tue Mar 09, 2004 4:53 pm     Reply with quote
You could use an external interrupt, which could start timer 0.
After say 10 seconds had elaspsed on the timer0. you could sound an alarm
Hope this helps!!
Best Regards
chingB
Re: Door switch
PostPosted: Tue Mar 09, 2004 5:10 pm     Reply with quote
Hope this helps!!
Is this algorithm will do the job or maybe share some tips and suggestions to improve this code.
#int_ext2
ext2_isr(){
   flag=1;
   doortmr=0;
   int2if=0;
main(){
   intedg2=1;
   int2if=0;
   enable_interrupts(int_ext2);
   enbale_interrupts(global);
   while(1){
      if (bit_test(PORTA,2) && (doortmr>=20))
         sound_alarm(ON);
      if (!bit_test(PORTA,2) && flag){
         sound_alarm(OFF); flag=0;
Thank u.
