Extrange Error HELLLLP!!!
MoofCba
PostPosted: Mon Mar 08, 2004 2:40 pm     Reply with quote
whats wrong with this code?
#include <16F877.h>
#device adc=10
#use delay(clock=10000000)
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#bit Conversion= ADCON0.2
int dato[2],puntero;
int16 AD[8]={0,1,2,3,4,5,6,7};
#int_AD
AD_isr()
#int_TBE
TBE_isr()
#int_RDA
RDA_isr()
Cos when i compile with CCS 3.184 i have this error:
UNDEFINED IDENTIFIER ?
a the compiler marks the line whith the int dato[2],puntero;
exactly the in of the int!!!!
why is this, this is my first proyect and i can make it work.
mvaraujo
PostPosted: Mon Mar 08, 2004 2:50 pm     Reply with quote
It seams to have a comma in the definition, right?
It shoudn't be there, use only:
int dato[2] puntero;
PostPosted: Mon Mar 08, 2004 3:00 pm     Reply with quote
Did you compile that code before you posted it ?
If he follows your recommendation, he will get this error.
*** Error 36 "C:\PICC\TEST\TEST.C" Line 19(13,20): Expecting a ; or ,
His problem is that he has not defined the ADCON0 symbol.
He needs to do that with a #byte statement.
