Using Hardware Interrupt (INT0)
ericzuki
View user's profile Send private message ICQ Number
PostPosted: Mon Mar 08, 2004 9:41 am     Reply with quote
Hi All
I have written a test program on INT0 but I am not able to test it out on the hardware yet due to unavalibility. Can someone be kind enough to tell me whether the code will works.
A push button is connected to Pin B0 which when pushed will caused the chip to go into SLEEP mode. A second push on the pushbutton will bring the chip active and reset via reset_cpu().
#include <18F458.h>
#use delay(clock=20000000)
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt when button pushed and released
#INT_EXT
void ext_isr()
   if(button_pressed_once)                // if button action and was not
                                                      // pressed
      button_pressed_once=FALSE;    //to activate the next button pressed
                                                     // which is to reset the thing
      sleep();
      button_pressed_once=TRUE;   // the button is now up
      reset_cpu();
   ext_int_edge(H_TO_L);      // init interrupt triggering for button press
   enable_interrupts(INT_EXT);// turn on interrupts
   static short button_pressed_once=TRUE;
jds-pic
Re: Using Hardware Interrupt (INT0)
PostPosted: Mon Mar 08, 2004 9:09 pm     Reply with quote
ericzuki wrote:
#INT_EXT
void ext_isr()
                                                      // pressed
      sleep();
      reset_cpu();
it may just be me but i don't like the idea of going to sleep inside an interrupt handler function. i believe that this is asking for debugging troubles and it's just not good programming practice. why not just set a flag in #int_ext and test it in main()? keep your inerrupt handlers simple.
jds-pic
