OSCCAL and compiler version 2.706
Doug
PostPosted: Mon Feb 16, 2004 10:08 pm     Reply with quote
Hi all, I am working on a project which uses a 12c672 chip. I have version 2.706 of the CCS compiler. Digging through the archives of this board I discovered that a problem with OSCCAL was fixed in 2.708 of the compiler. Does anyone know what the fix was? My assembly output of the call to the OSCCAL calibration looks likes this after I compile the code:
0000  3000          movlw  0x0
0001  008A          movwf  0xA
0002  2828          goto   0x28
.       // serveral lines of assembly
0028  3007          movlw  0x7
0029  008A          movwf  0xA
002A  27FF          call   0x7FF
002B  0085          movwf  0x5
002C  3000          movlw  0x0
002D  008A          movwf  0xA
002E  287A          goto   MAIN
Does it look correct? If not what should I do to fix it?
Doug
Felix Althaus
PostPosted: Tue Feb 17, 2004 6:36 am     Reply with quote
Hello
I don't remeber how much ROM the 672 has, but if it's 2048 words, your code seems to be correct (if there is a 'RETLW XX' instruction at address 0x7FF).
Felix
Doug
PostPosted: Tue Feb 17, 2004 9:55 am     Reply with quote
Ok, good Very Happy . Its a 2K rom, I just wasn't sure if there was a change made which affected the loading of the OSCCAL register.
Thanks,
Doug
Felix Althaus
PostPosted: Tue Feb 17, 2004 10:21 am     Reply with quote
Hello Doug
I'm very sorry but I think I have overlooked something:
Your compiler stores the osccal value in the register 0x05 but that's the GPIO. Can you have a look at the PIC12c672 output of the picchips program? What does it say about the osccal register location?
If the fault is there, perhaps you can correct it with the device table editor. If you don't have one you can use this code (as I do):
#byte OSCCAL = 0x8F
// somewhere at the beginning of main():
OSCCAL = YOUR_VALUE;
The compiler should handle the bank switching automatically.
Felix
Doug
PostPosted: Tue Feb 17, 2004 11:12 am     Reply with quote
Ahhh... yes, the data sheet says the OSCCAL value is at 8F. I thought it was kind of strange that the value got writen to 05 but I figured it was due to bank selection.
So if I program multiple chips can I do my own routine at the beginning like:
#byte OSCCAL = 0x8F
main(){
// initialization code
#asm
          movlw  0x07
          movwf  0x0A
          call   0x7FF
          movwf  OSCCAL
          movlw  0x00
          movwf  0x0A
#endasm
// rest of program
Can I put that in my code to fix the problem?
Thanks,
Doug
Felix Althaus
PostPosted: Tue Feb 17, 2004 1:19 pm     Reply with quote
Yes that's possible, but I don't know if the compiler accepts a #byte-definition within assembly code. Perhaps you have to define OSCCAL with:
#define OSCCAL 0x8F
Perhaps you also have to switch to the correct bank (and back) before moving the return value to OSCCAL.
Felix
Doug
PostPosted: Tue Feb 17, 2004 1:46 pm     Reply with quote
Ok, according to the data sheet I only have to set bit 5 of register 3 (status register) to switch banks. But what does putting 0x07 into PCLATH (0A) before the call to 0x7FF do? Is this another form of bank switching? I'm confused about the use of banks.
Thanks,
Doug
Felix Althaus
PostPosted: Tue Feb 17, 2004 3:15 pm     Reply with quote
Hi
The 0x07 into PCLATH is the "page switch" so the PIC can access the upper program memory pages (in this case the highest one where the retlw XX lies).
Have a look at the datasheet.
Felix
Doug
PostPosted: Tue Feb 17, 2004 3:36 pm     Reply with quote
Thanks Felix!
I didn't know "page switch" and "bank select" were two different things. I need to learn more. Confused
I'll look into it.
Doug
PostPosted: Tue Feb 17, 2004 5:47 pm     Reply with quote
Ok I think I have it now.....
Here's what I did:
#define OSCCAL 0x8f
main(){
// initialization code here
#asm
   movlw  0x07
   movwf  0x0A
   call   0x7FF
   movwf  OSCCAL
   movlw  0x00
   movwf  0x0A
#endasm
// rest of program
And here is what it looks like after I compiled it:
          movlw  0x7
          movwf  0xA
          call   0x7FF
          bsf    0x3,0x5
          movwf  0xF
          movlw  0x0
          bcf    0x3,0x5
          movwf  0xA
Notice how CCS took care of the bank selection bit automatically. Now when I run MPLAB Simulator it updates the OSCCAL register properly.
Thank you Felix, for helping me with this work around.
