highest baud rate on PIC16F877A
pfo
PostPosted: Sun Feb 15, 2004 2:27 pm     Reply with quote
what's the highest baud rate on PIC16F877A, any pitfalls?
thx
pfo
Re: highest baud rate on PIC16F877A
PostPosted: Sun Feb 15, 2004 3:33 pm     Reply with quote
thx
pfo
I have used over 500K baud.
The problems are that for reception, you must be able to deal with each byte in the time available, if overrun errors are to be avoided. The latency involved in the standard interrupt handler, can be too large for faster rates (I coded my own 'int global', and only saved the very minium registers used in the handler code).
There are also the obvious external problems (the transceivers themselves have limits on teh speeds they can operate, allowable cable lengths get shorter the faster the rate etc..).
Remember also that generally, the higher the rate, the greater the likelyhood of significant baud rate errors if the crystal used is not carefully selected to be a multiple of the required rate.
