LCD & KBD with PIC16F877A and with PORT-D
aminij_software
PostPosted: Sat Feb 14, 2004 1:19 pm     Reply with quote
Dear Sir,
I require to drive LCD and KBD at PORT D. I am using a device PIC 16F877A. I change the CCS Default LCD and KBD driver code as below. But the only LCD works, the keyboard doesn't work. I also try to add external pullups with 10K resistor on PORT D.
but the keyboard doesn't work. what was going wrong.
Please specify me how to solve this problem. I am using a CCS compiler version 3.082.
/****************LCD.c************************/
//// LCD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// As defined in the following structure the pin connection is as follows:
// B0 enable
// B1 rs
// B2 rw
// B4 D4
// B5 D5
// B6 D6
// B7 D7
// LCD pins D0-D3 are not used and PIC B3 is not used.
struct lcd_pin_map { // This structure is overlayed
boolean enable; // on to an I/O port to gain
boolean rs; // access to the LCD pins.
boolean rw; // The bits are allocated from
boolean unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#byte lcd = 8
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
byte lcd_read_byte() {
byte low,high;
set_tris_d(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_d(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( byte n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( byte address, byte n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
byte i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( byte x, byte y) {
byte address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( byte x, byte y) {
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
/****************KBD.c************************/
//// KBD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
////////////////// The following defines the keypad layout on port B
#byte kbd = 8
//Keypad connection: (for example column 0 is B2)
// Bx:
#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2)
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
char kbd_getc( ) {
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : set_tris_d(ALL_PINS&~COL0);
kbd=~COL0&ALL_PINS;
case 1 : set_tris_d(ALL_PINS&~COL1);
kbd=~COL1&ALL_PINS;
case 2 : set_tris_d(ALL_PINS&~COL2);
kbd=~COL2&ALL_PINS;
if(kbd_down) {
if((kbd & (ALL_ROWS))==(ALL_ROWS)) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
if((kbd & ROW0)==0)
row=0;
else if((kbd & ROW1)==0)
row=1;
else if((kbd & ROW2)==0)
row=2;
else if((kbd & ROW3)==0)
row=3;
last_key =KEYS[row][col];
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
set_tris_d(ALL_PINS);
return(kchar);
Sad Sad
guest
PostPosted: Sat Mar 06, 2004 6:24 am     Reply with quote
i used a while loop for the kbd function for a project i was working on
and this solved the problem i was having. check the code for the added while ***********
[Post] Posted: Sat Feb 14, 2004 1:19 pm [Reply with quote]
Dear Sir,
//// KBD.C ////
#byte kbd = 8
// Bx:
// Keypad layout:
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
char kbd_getc( ) {
static byte col;
byte kchar;
byte row;
kchar='\0';
while(kchar==0){ //put this in*********
switch (col) {
kbd=~COL0&ALL_PINS;
kbd=~COL1&ALL_PINS;
kbd=~COL2&ALL_PINS;
if(kbd_down) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if((kbd & ROW0)==0)
row=0;
row=1;
row=2;
row=3;
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
}// finish here*************************
return(kchar);
hope this works Smile
aminij_software
PostPosted: Sat Mar 06, 2004 2:59 pm     Reply with quote
the code works but goes in to the while loop and only quit from while any key is pressed. please specify me how to solve this problem
Dear Sir,
//// KBD.C ////
#byte kbd = 8
// Bx:
// Keypad layout:
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
char kbd_getc( ) {
static byte col;
byte kchar;
byte row;
kchar='\0';
switch (col) {
kbd=~COL0&ALL_PINS;
kbd=~COL1&ALL_PINS;
kbd=~COL2&ALL_PINS;
if(kbd_down) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if((kbd & ROW0)==0)
row=0;
row=1;
row=2;
row=3;
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
return(kchar);
aminij_software
PostPosted: Sat Mar 06, 2004 3:06 pm     Reply with quote
Dear Sir,
//// KBD.C ////
#byte kbd = 8
// Bx:
// Keypad layout:
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
char kbd_getc( ) {
static byte col;
byte kchar;
byte row;
kchar='\0';
switch (col) {
kbd=~COL0&ALL_PINS;
kbd=~COL1&ALL_PINS;
kbd=~COL2&ALL_PINS;
if(kbd_down) {
kbd_down=false;
kchar=last_key;
last_key='\0';
} else {
if((kbd & ROW0)==0)
row=0;
row=1;
row=2;
row=3;
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
return(kchar);
guest
PostPosted: Sat Mar 06, 2004 4:48 pm     Reply with quote
i am a newbie to microcontrollers and such, but if you are calling kbd
then don't you want to stay in the function until a key is pressed?
maybe i am missing what the problem is you are now having, can you give more details on what you want the code to do?
i hope this helps[/quote]
