ICD-U40 mysterious errors programming EEProm :-(
grunwald
PostPosted: Thu Jan 15, 2004 4:08 am     Reply with quote
I use PCWH 3.184 to compile for a PIC18LF452 running at 3.3V with 20MHz. To debug and program the pic I use the integrated ICD-U40 interface V2.7 and the ICD Firmware 1.20 for PIC 16 and PIC 18.
My EEPROM declaration looks like the following:
#rom int8 0xF00000 = { 0xaa }
#rom int8 0xF00001 = { 0xab }
#rom int8 0xF000FF = { 0x11 }
The compilation is no problem. But if the Debugwindow programs the Device via the ICD-U40 the following errors Occur at the following Adresses:
0xF00043
Error: Could not write to target data EEPROM: Did noch ack message 45
0xF00087
Error: The ICD did not return the request amount of data
0xF000CC
If I change the order of the adress definitions in the sourcecode like the following,
there is no problem transfering the data to the PIC. Perhaps there is a timeout problem in the ICD-40 software or firmware??
#rom int8 0xF00044 = { 0xab }
#rom int8 0xF00043 = { 0x22 }
#rom int8 0xF00045 = { 0xac }
#rom int8 0xF00088 = { 0xab }
#rom int8 0xF00087 = { 0x33 }
#rom int8 0xF00089 = { 0xac }
#rom int8 0xF000CD = { 0xab }
#rom int8 0xF000CC = { 0x44 }
#rom int8 0xF000CE = { 0xac }
Could You please tell me what to do to bring my code back in order again?
PS. The ICD Control Program is of the Opinion that the PIC is running at
4.85V?!? But it IS running with 3.3V! I do not hope this is the problem
Thank You for Your support,
Bernd Grunwald
bgpartri
PostPosted: Thu Feb 12, 2004 5:35 pm     Reply with quote
I'm getting the same problem. I will see if I can get it to work by rearranging it.
18F452 and 3.178, 3.184 tested
bgpartri
PostPosted: Thu Feb 12, 2004 6:40 pm     Reply with quote
Yes, it works if you make it non-contiguous.
#ROM 0xF000C4 = { 0x696C, 0x6574, 0x6445, 0x7469, 0x4C20,
0x776F, 0x5320, 0x4550, 0x6964, 0x2074,
0x6948, 0x6867, 0x5320, 0x0050
#ROM 0xF0007A = { 0x6863, 0x7420, 0x206F, 0x654D, 0x6574,
0x7372, 0x7753, 0x7469, 0x6863, 0x7420,
0x206F, 0x6546, 0x7465, 0x6F4C, 0x2077,
0x5053, 0x6948, 0x6867, 0x5320, 0x4550,
#ROM 0xF0003E = { 0x6374, 0x2068, 0x6F74, 0x4F20, 0x5343,
0x6964, 0x2074, 0x6F43, 0x766E, 0x7265,
0x4576, 0x6964, 0x2074, 0x6142, 0x6B63}
0x6977, 0x6374, 0x2068, 0x6F74, 0x4320,
0x5343, 0x7465, 0x7075, 0x6544, 0x6966,
0x656E, 0x4720, 0x7361, 0x6F43, 0x736E,
0x7265, 0x6176, 0x6974, 0x6D73, 0x6142,
0x6B63, 0x696C, 0x6574, 0x7753, 0x7469}
