Felix Althaus
Joined: 09 Sep 2003 Posts: 67 Location: Winterthur, Switzerland
| temporary undoing a #define (?) |
Posted: Wed Jan 14, 2004 10:30 am |
Hello
I have this code:
#define BUTTON PIN_A1
#if(BUTTON / 8 != 5)
#error BUTTON has to be on PortA
I want to check, if BUTTON was assigned to a pin on Port A. If not a message should appear. The problem is, that in the error message BUTTON is replaced by the internal compiler value (ok, I know, the pre-processor does here what he sould do...).
Is there a way I can "undefine" BUTTON just for this time so it will print "BUTTON" instead of a number?
Many thanks
Felix |
| Re: temporary undoing a #define (?) |
Posted: Wed Jan 14, 2004 11:24 am |
| Felix Althaus wrote: | Hello
I have this code:
Many thanks
Felix |
#undef BUTTON
#endif |
