Anybody have done this code...
rrb011270
View user's profile Send private message Yahoo Messenger
PostPosted: Tue Oct 07, 2003 11:32 pm     Reply with quote
Mabuhay!
Anyone in the forum have done I2C using hardware for writing/reading to FM24C256 w/o using the ccs built-in functions....
It wud be better if somebody share to me a sample code which use interrupt and hardware I2C at the same time...
Any help will do?
Thnx
Mark
PostPosted: Wed Oct 08, 2003 6:29 am     Reply with quote
See below
Mark
PostPosted: Wed Oct 08, 2003 6:30 am     Reply with quote
This code does not use interrupts but does use the hardware i2c. It does not use any CCS functions since I wrote it for the Microchip C18 compiler. I didn't post all the typedefs but they should be clear. Also note that this was done for a 24C08 so the addressing scheme would be a little different but it should give you a starting point.
  Useful defines for writing to the I2C bus
#define I2C_IDLE()  while ((SSPCON2 & 0x1F) || (SSPSTATbits.R_W))
#define I2C_START() \
  SSPCON2bits.SEN = 1; \
while (SSPCON2bits.SEN) \
  _asm nop _endasm \
#define I2C_RESTART() \
  SSPCON2bits.RSEN = 1; \
  while (SSPCON2bits.RSEN) \
    _asm nop _endasm \
#define I2C_STOP() \
  SSPCON2bits.PEN = 1; \
  while (SSPCON2bits.PEN) \
    _asm nop _endasm \
#define I2C_WRITE(x) \
  SSPBUF = (x); \
  while (SSPSTATbits.BF) \
    _asm nop _endasm \
  I2C_IDLE()
#define I2C_READ(x) \
  SSPCON2bits.RCEN = 1; \
  while (SSPCON2bits.RCEN) \
    _asm nop _endasm \
  SSPCON2bits.ACKDT = (x); \
  SSPCON2bits.ACKEN = 1; \
  while (SSPCON2bits.ACKEN) \
    _asm nop _endasm \
static BOOLEAN  I2C_Device_Ready(UINT8 id);
void            EEPROM_Write_Internal(UINT8 data, UINT16 address);
UINT8           EEPROM_Read_Internal(UINT16 address);
void            EEPROM_Write_Byte(UINT8 data, UINT16 address);
UINT8           EEPROM_Read_Byte(UINT16 address);
void            EEPROM_Write_String(char *s, UINT16 address);
void            EEPROM_Read_String(char *s, UINT16 address);
void            EEPROM_Write_Block(char *data, UINT8 len, UINT16 address);
void            EEPROM_Read_Block(char *data, UINT8 len, UINT16 address);
  DESCRIPTION:  This function checks to see if an i2c device will ACK
  RETURN: TRUE if device ACKed otherwise FALSE
  ALGORITHM:  none
  NOTES:  none
  UINT8 id) /* FIX ME: add comment */
  do
    /* Important to clear these bits before we attempt to write */
    PIR2bits.BCLIF = 0;
    SSPCON1bits.WCOL = 0;
    I2C_IDLE();             /* ensure module is idle */
    I2C_START();
  } while (PIR2bits.BCLIF);
  I2C_WRITE(id);
  if (!SSPCON2bits.ACKSTAT) /* test for ACK condition, if received */
    return (TRUE);
  return (FALSE);
  DESCRIPTION:  This function writes the passed data to the specified
                address of the serial eeprom.
  RETURN: none
  ALGORITHM:  none
  NOTES:  none
  UINT8   data,     /* byte written to seeprom */
  UINT16  address)  /* SEEPROM address to write data */
  UINT8 control;
  /* MSB if address > 0xFF. Should be in bit1 */
  control = SEEPROM_WRITE_MODE | ((UINT8) (address >> 8) << 1);
  while (!I2C_Device_Ready(control));
  I2C_WRITE((UINT8) address);
  I2C_WRITE(data);
  I2C_STOP();
  DESCRIPTION:  This function reads a byte of data in from the serial
                eeprom at the specified address.
  RETURN: data byte read from SEEPROM
  ALGORITHM:  none
  NOTES:  none
  UINT16  address)  /* seeprom address to write data */
  UINT8 control;
  control = SEEPROM_WRITE_MODE | (UINT8) (address >> 8) << 1;
  I2C_RESTART();
  I2C_WRITE(control + 1);
  I2C_READ(1);
  I2C_STOP();
  return (SSPBUF);  /* return with data */
  DESCRIPTION:  This function writes a byte of data to the specified
                address of the internal eeprom.
  RETURN: none
  ALGORITHM:  none
  NOTES:  none
  UINT8   data,     /* byte written to eeprom */
  UINT16  address)  /* EEPROM address to write data */
  EEADRH = address >> 8;  /* Load our address */
  EEADR = address;        /* Load our address */
  EEDATA = data;          /* Load our data */
  EECON1bits.EEPGD = 0;   /* Point to data memory */
  EECON1bits.WREN = 1;    /* Enable writes */
  /* Microchip recommends disabling ints here */
  Global_Int(INT_DISABLED);
  EECON2 = 0x55;          /* Write 0x55 */
  EECON2 = 0xAA;          /* Write 0xAA */
  EECON1bits.WR = 1;      /* Set WR to begin write */
    _asm nop _endasm
  Global_Int(INT_RESTORE);
  while (EECON1bits.WR)   /* Wait for write to complete */
    _asm nop _endasm
  EECON1bits.WREN = 0;    /* Disable writes */
  return;
  DESCRIPTION:  This function reads a byte of data in from the internal
  RETURN: data - byte read from SEEPROM
  ALGORITHM:  none
  NOTES:  none
  UINT16  address)  /* eeprom address to write data */
  EECON1bits.RD = 1;      /* EEPROM Read */
  return (EEDATA);        /* Return with our value */
  DESCRIPTION:  This function writes a string to the SEEPROM
  RETURN: none
  ALGORITHM:  none
  NOTES:  The routine should handle going across chip boundaries
  char    *s,       /* string to write to seeprom */
  EEPROM_Write_Block(s, strlen(s) + 1, address);
  DESCRIPTION:  This function reads a string from the serial eeprom at the
                specified address.
  RETURN: none
  ALGORITHM:  none
  NOTES:  This routine does not cross chip boundaries
  char    *s,       /* point to the string to load */
  UINT8 control;
  /* check for a valid pointer */
  if (s == 0)
    return;
  I2C_RESTART();
  while (TRUE)
    I2C_READ(0);
    *s = SSPBUF;
    if (*s == 0)
    s++;
  /* Terminate the read sequence */
  I2C_READ(1);
  I2C_STOP();
  DESCRIPTION:  This function writes a block of data to the SEEPROM
  RETURN: none
  ALGORITHM:  none
  char    *data,    /* pointer to the block of data to write */
  UINT8   len,      /* number of bytes to write */
  UINT8 control;
  UINT8 lastpage;
  UINT8 page;
  /* determine the control word for the device */
  /* Wait until our device is ready */
  /* Set the address pointer in the device */
  page = (UINT8) address >> 4;
  lastpage = page;
  while (len)
    if (page != lastpage)
      /* Issuing a STOP will start the write sequence */
      I2C_STOP();
      lastpage = page;
    I2C_WRITE(*data);
    data++;
    address++;
    /* The 24C08 has a 16 byte page for writing. */
    len--;
  I2C_STOP();
  DESCRIPTION:  This function reads a block of data from the serial eeprom
  RETURN: none
  ALGORITHM:  none
  char    *data,    /* point to the data to load */
  UINT8   len,      /* number of bytes to read */
  UINT8 control;
  I2C_RESTART();
  while (len > 1)
    I2C_READ(0);
    *data = SSPBUF;
    data++;
    len--;
  I2C_READ(1);
  *data = SSPBUF;
  I2C_STOP();
rrb011270
PostPosted: Wed Oct 08, 2003 5:29 pm     Reply with quote
what is the purpose of "\" symbol?
_asm nop _endasm \
rrb011270
PostPosted: Wed Oct 08, 2003 7:39 pm     Reply with quote
Hi Mark,
With the code u mention... Do I have to have to use the #use i2c(master,...)?
thnx
Mark
PostPosted: Wed Oct 08, 2003 7:52 pm     Reply with quote
The "\" means continuation. It is a way to break up a long line of C code.
You will have to set up the ssp. I don't use the #use i2c. As I said before, this was done for the C18 compiler which does not have the CCS functions.
PostPosted: Wed Oct 08, 2003 9:43 pm     Reply with quote
Hi Mark,
I compile the code u shared but it report an error with an unknown indentifier "_asm".
Can u check if this will work in PIC18452.
Thnx
Mark
PostPosted: Thu Oct 09, 2003 6:10 am     Reply with quote
This code was written for the MICROCHIP C18 compiler! Although it is C, you will have to make a few changes. CCS embeds their assembly a little differently. The Global_Int() function is one that I wrote that saves the current state of the interrupts (high and low priority) when they are disabled. I can then call the restore and they are set back to the state before I disabled them. This keeps me from enabling interrupts if they were already disabled for some reason. Also note that you will have to define all the registers.
PostPosted: Thu Oct 09, 2003 5:19 pm     Reply with quote
Would it be possible to share a simple code snippet regarding Global_Int() and restore function? maybe I can utilize it with my application.
Thnx
rrb011270
PostPosted: Sat Oct 11, 2003 6:22 am     Reply with quote
I have successfully converted the code u shared to PIC18452... I'll post this coming monday for others can have it use it in der project...
Tengkyu
rrb011270
PostPosted: Tue Oct 14, 2003 8:26 am     Reply with quote
I have succesfully coded the source below for the PIC18F452...
I write to an external FRAM without affecting my timer interrupt (RTC) and other interrupt that I use (e.g. rda, tbe, timer1)... and it really did write without hanging-up my system..
My only convern is that would this affect my RTC and other interrupts if I am to read block of data from FRAM memory? say read 128bytes of data and send it to serial using interrupt(#int_rda)? such that my host PC will parse it.....
Anybody who can give me a tips, comments or any help will do....
  _asm nop _endasm \
    _asm nop _endasm \
    _asm nop _endasm \
  SSPBUF = (x); \
    _asm nop _endasm \
  I2C_IDLE()
    _asm nop _endasm \
    _asm nop _endasm \
  ALGORITHM:  none
  NOTES:  none
  do
    PIR2bits.BCLIF = 0;
    I2C_START();
  I2C_WRITE(id);
    return (TRUE);
  return (FALSE);
  RETURN: none
  ALGORITHM:  none
  NOTES:  none
  UINT8 control;
  I2C_WRITE(data);
  I2C_STOP();
  ALGORITHM:  none
  NOTES:  none
  UINT8 control;
  I2C_RESTART();
  I2C_READ(1);
  I2C_STOP();
  RETURN: none
  ALGORITHM:  none
  NOTES:  none
    _asm nop _endasm
    _asm nop _endasm
  return;
  ALGORITHM:  none
  NOTES:  none
  RETURN: none
  ALGORITHM:  none
                specified address.
  RETURN: none
  ALGORITHM:  none
  UINT8 control;
  if (s == 0)
    return;
  I2C_RESTART();
  while (TRUE)
    I2C_READ(0);
    *s = SSPBUF;
    if (*s == 0)
    s++;
  I2C_READ(1);
  I2C_STOP();
  RETURN: none
  ALGORITHM:  none
  UINT8 control;
  UINT8 lastpage;
  UINT8 page;
  lastpage = page;
  while (len)
      I2C_STOP();
      lastpage = page;
    I2C_WRITE(*data);
    data++;
    address++;
    len--;
  I2C_STOP();
  RETURN: none
  ALGORITHM:  none
  UINT8 control;
  I2C_RESTART();
  while (len > 1)
    I2C_READ(0);
    *data = SSPBUF;
    data++;
    len--;
  I2C_READ(1);
  *data = SSPBUF;
  I2C_STOP();
