Target not in debug mode?
Chen
PostPosted: Wed Feb 12, 2003 10:32 am     Reply with quote
I tried out a sample code, it compiled fine, but when I program it in MPLAB, everything seems fine until verification:
Programming Target...
...Erasing Part
...Programming Program Memory
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
...Programming RSBUG
...Programming Configuration Bits
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
.. Config Memory
ICD0083: (CICDController::EnterDebugMode) Target not in debug mode, unable to perform operation
...Programming failed
Any suggestion?
Thanks!
Original Post ID: 11603
Gavin
Re: Target not in debug mode?
PostPosted: Thu Feb 13, 2003 1:06 pm     Reply with quote
I am having the same problem too... did you ever resolve this issue?
:=I tried out a sample code, it compiled fine, but when I program it in MPLAB, everything seems fine until verification:
:=Programming Target...
:=...Erasing Part
:=...Programming Program Memory
:=...Loading DebugExecutive
:=...Programming DebugExecutive
:=...Programming Debug Vector
:=...Programming RSBUG
:=...Programming Configuration Bits
:=Verifying...
:=...Program Memory
:=...Debug Executive
:=...Debug Vector
:=...Verify Succeeded
:=.. Config Memory
:=ICD0083: (CICDController::EnterDebugMode) Target not in debug mode, unable to perform operation
:=...Programming failed
:=Any suggestion?
:=Thanks!
Original Post ID: 11652
poulholmoethomsen
PostPosted: Mon Feb 17, 2003 8:24 am     Reply with quote
:=...Erasing Part
:=Verifying...
:=...Program Memory
:=...Debug Vector
:=.. Config Memory
:=Any suggestion?
:=Thanks!
In the configuration bit window - Background debug should be disabled.
good luck
Poul
Original Post ID: 11787
