Macro help
pat
Macro help
PostPosted: Wed Sep 24, 2003 8:15 am     Reply with quote
I'm trying to write a macro to improve readability
Here's the definition
#define turnfeton (a, b)   {if (a) output_low (b); else output_high (b)}
#define bitpos_invert_fet_1     4   // Bit position for trig 1 invert flag
#define bitpos_invert_fet_2     5   // Bit position for trig 2 invert flag
#define bitpos_invert_fet_3     6   // Bit position for trig 3 invert flag
#define bitpos_invert_fet_4     7   // Bit position for trig 4 invert flag
#define fet_1                         pin_b2
Here's how I call it from the code
int8 invert_flags = 0xf0;
turnfeton (bit_test (invert_flags, bitpos_invert_fet_1), fet_1);
The compiler says undefined identifier 'a'. Is there another way of doing this? I tried replacing the curly brackets with normal, but no difference.
I tried writing a function, but couldn't pass a pin as a parameter, even when I defined the parameter as a const int8.
PostPosted: Wed Sep 24, 2003 9:11 am     Reply with quote
I got it to compile without errors after I did this:
1. Removed the space between turnfeton and (a,b).
2. Removed the { } braces.
pat
PostPosted: Wed Sep 24, 2003 4:51 pm     Reply with quote
Excellent thanks PCM, I will try it out tonight. It looks like the first element of the macro must be without spaces.
One more question, could I extend the macro to do this?
#define turnfeton(a,b)      if (bit_test (invert_flags, a)) output_low (b); else output_high (b)
I would call this macro from the code as follows
turnfeton (bitpos_invert_fet_1, fet_1);
Thanks again
Mark
PostPosted: Wed Sep 24, 2003 5:25 pm     Reply with quote
What not just write functions for them. The macros are not going to save any code space verses inline functions.
Something like:
void turnfet1on(int8 bit)
  if (bit_test (invert_flags, bit))
    output_low (fet_1);
    output_high (fet_1);
void turnfet2on(int8 bit)
    output_low (fet_2);
    output_high (fet_2);
turnfet1on (bitpos_invert_fet_1);
turnfet2on (bitpos_invert_fet_2);
or you could use a switch:
#define fet1         1
#define fet2         2
void turnfeton(int8 bit, int8 fet)
  switch (fet)
    case fet1:
        output_low (fet_1);
    case fet2:
        output_low (fet_2);
    default:
turnfeton(bitpos_invert_fet_1,fet1);
turnfeton(bitpos_invert_fet_1,fet2);
pat
PostPosted: Wed Sep 24, 2003 8:37 pm     Reply with quote
Thanks Mark, I initially tried using a function, but I couldn't work out how to pass a port pin as a parameter. I later saw in the help that you need to do a switch as you suggest.
Reducing code space wasn't my primary concern, I was trying to improve the readability of my code.
I actually like your first solution of having a function for each fet (I have 4 in total).
I've not used macros before, and I'd like to understand how to use them also.
Neutone
PostPosted: Thu Sep 25, 2003 7:54 am     Reply with quote
I have had to deal with a motor that runs the other direction when the line power is phased CBA instead of ABC. I do a phase check and set a phase bit. If I want Clockwise rotation I set CW and for Counter Clockwise direction CCW. I knkow this is not what your tring to do but it may give you some ideas
if(CW)
{   Fet1=phase;
     Fet2=!phase;
     Fet3=phase;
     Fet4=!phase;
if(CCW)
{   Fet1=!phase;
     Fet2=phase;
     Fet3=!phase;
     Fet4=phase;
if(!CW&&!CCW)
{   Fet1=0;
     Fet2=0;
     Fet3=0;
     Fet4=0;
