Meausuring Pulse widths (bit banging on 16F84)- Not working.
Freddie
PostPosted: Sun Sep 07, 2003 5:54 pm     Reply with quote
As a building block for a larger project I'm outputting a positive going 190us pulse from one 16F84 and trying to measure the pulse width on another 16F84. I know that bit banging is not the most accurate way to do this but I'm OK with that, this is just a test program. No matter what I do I can't get the receiving 16F84 to read the pulse width correctly. It is off by orders of magnitude and not the same every time. I've used a scope to make sure the pulse is being transmitted at the correct width. I am using the a crystal that matches the clock speed defined in the program.
There must be something obvious that I am missing.
Here is the code for both the transmitter and receiver. If anyone can see anything obvious I would appreciate your comments. I tried with CCS PCM 3.148 and 3.176.
TRANSMITTER 16F84
#include <16f84.h>
#case
#fuses HS,NOWDT,PUT,NOPROTECT
#use delay(clock=10000000)
#zero_ram
// ----- Definitions
#define statusLED PIN_A0
#define txData PIN_A1
// ----- Function Prototypes
//void transmitZero(void);
// ----- Glogal Variables
int i;
output_low(txData); //off
delay_ms(5000); //rest time and stabilize
output_high(txData); //on
delay_us(190);
//do nothing
} //end main
// ----- Functions
RECEIVER 16F84#include <16f84a.h>
#case
#use delay(clock=20000000)
#zero_ram
#define LEDStatus PIN_A0
#define rxData PIN_B4
#define TxPC PIN_A2
#define RxPC PIN_A3
#define numSamples 10
#use rs232(BAUD=57500, XMIT=TxPC,RCV=RxPC) //setup for rs232 Debug.
int i;
int pulseCount;
for(i=1;i<=3;i++)
output_low(LEDStatus); //on
delay_ms(50);
output_high(LEDStatus); //off
printf("Reset: ");
puts(":>");
pulseCount = 0;
while(!input(rxData)) //no data
// do nothing, wait for data
while(input(rxData)) && (pulseCount <= 250)) {
pulseCount = pulseCount + 1;
delay_us(1);
Shocked
printf("pulseCount %X", pulseCount);
puts(":>");
} //end main
// ----- Functions
PostPosted: Sun Sep 07, 2003 8:02 pm     Reply with quote
In your loop below, your assumption is that the loop code will
execute almost instantaneously, and the only delay is in the
delay_us(1) statement.
But, if you look at the .LST file, you'll see that it takes many
instructions to execute the loop. This is where the extra
delay is coming from.
With a 10 MHz clock, you'll get 2.5 instruction cycles per usec.
You can count instructions in the .LST file to see how long
your loop code will take. Some instructions, such as GOTO
or Branch instructions (that do the jump) will take 2 instruction
cycles.
delay_us(1);
Freddie
PostPosted: Tue Sep 09, 2003 1:41 pm     Reply with quote
Yes, I see this now. My assumption that the most significant delay is in the delay_us(1) is in error. I'm using the timers now and it works great.
Thanks PCM Programmer!
