How do we use internal oscillator?
June
PostPosted: Wed Dec 04, 2002 10:26 pm     Reply with quote
Dear Sir,
I heard PIC got its own internal oscillator also. But when I check the datasheet of PIC16F876 I couldn't find it. Is that because it doesn't has internal oscillator?
Can I know what is the advantages and disadvantages of using internal internal oscillator. I mean besides external oscillator takes extra place, what are the differences. Does PIC16F84 has internal oscillator also?
Finally, may I know in CCS compiler how do we set the program to use internal oscillator?
Thanks for reading...
Regards: June,
Original Post ID: 9786
Tomi
Re: How do we use internal oscillator?
PostPosted: Thu Dec 05, 2002 2:28 am     Reply with quote
<font face="Courier New" size=-1>Not all of PICs have internal oscillator. As I know only the 8-pin PICs (e.g. 12C508/509, 12CE518,519, 12F675, etc. , internal 4MHz oscillator) and the 18-pin 16F62X series (internal 4MHz/37kHz) have internal osc.
No internal osc in 16F84 but you can use 16F627/628 instead of 16F84. It is pin-compatible with 16F84 and has internal 4MHz/37kHz oscillator.
Advantages: cheaper (you don't need any crystal) and saves 2 PIC pins (what is a real advantage using 8-pin PICs Smile )
Disadvantage: it is not as accurate as crystal osc.
Usage:
enter the right option at your #fuses keyword e.g.:
#include <12ce519.h>
#fuses INTRC,WDT,PROTECT,NOMCLR // INTRC to use 4MHz internal osc.
:=Dear Sir,
:= I heard PIC got its own internal oscillator also. But when I check the datasheet of PIC16F876 I couldn't find it. Is that because it doesn't has internal oscillator?
:= Can I know what is the advantages and disadvantages of using internal internal oscillator. I mean besides external oscillator takes extra place, what are the differences. Does PIC16F84 has internal oscillator also?
:= Finally, may I know in CCS compiler how do we set the program to use internal oscillator?
:= Thanks for reading...
:=Regards: June,</font>
Original Post ID: 9790
