18f452 EEPROM not working
SL1978
PostPosted: Sun Aug 11, 2002 7:22 pm     Reply with quote
I program my 18f452 with PCH 3.06. I had downloaded The suggested solution form mark and use in my program. Unfortunately it still doesn't work. The EEDATA always hold the last written value when we try to read back the eeprom contain.
Attached is a code of mine, can you kindly consult me where is the problem?
Thanks & regards,
Law
///my program///
#include <18f452.h>
#fuses xt,noprotect,nowdt,put,brownout,nolvp
#use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
//--------------------------- old version -------------------------------------
#define EEADR 0xFA9
#define EEDATA 0xFA8
#define EECON1 0xFA6
#define RD 0
#define WR 1
#define WREN 2
#define WRERR 3
#define FREE 4
#define CFGS 6
#define EEPGD 7
#define EECON2 0xFA7
#define PIR2 0xFA1
#define EEIF 4
void writeeeprom(int address, int data)
bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
(int)*EEADR = address; // Load our address
(int)*EEDATA = data; // Load our data
bit_clear(*EECON1, EEPGD); // Point to data memory
bit_set(*EECON1, WREN); // Enable writes
// Microchip recommends disabling ints here
disable_interrupts(GLOBAL);
(int)*EECON2 = 0x55; // Write 0x55
(int)*EECON2 = 0xAA; // Write 0xAA
bit_set(*EECON1, WR); // Set WR to begin write
// Ok to turn back on ints
// Wait for the write to complete
while (!bit_test(*PIR2, EEIF));
bit_clear(*EECON1, WREN); // disable writes
int readeeprom(int address)
bit_set(*EECON1, RD); // EEPROM Read
return(*EEDATA); // Return with our value
main()
{ int8 ctr, ctr2, ctr3,i;
SET_UART_SPEED(19200);
for(ctr = 100; ctr<=110; ctr++)
ctr2 = ctr - 100 + 1;
writeeeprom(ctr, ctr2);
ctr = 100;
putc(13);
ctr3 = readeeprom(ctr);
printf("addr = \%u eep = \%u", ctr,ctr3);
if(ctr<110)
ctr++;
ctr=100;
delay_ms(600);
Original Post ID: 6317
Peter H Anderson
Re: 18f452 EEPROM not working
PostPosted: Sun Aug 11, 2002 10:28 pm     Reply with quote
I struggled with this for some time and discovered the cfgs bit must be cleared.
Attached are sample routines which I have recently tested. Note that I use a header file which defines all SFRs and bit within the SFRs. However, you should be able to read this.
Note that when I wrote this CCS had not defined the EE interrupt for the PIC18F. Thus, I am simply waiting 10 ms for the programming.
byte read_data_eeprom(byte adr)
cfgs = 0; // this is critical
EEADR=adr;
eepgd = 0; // select data EEPROM
rd=1; // set the read bit
return(EEDATA);
void write_data_eeprom(byte adr, byte d)
byte gie_flag;
cfgs = 0;
EEADR = adr;
EEDATA = d;
#ifdef EE_INT
eeif = 0;
eeie = 1;
peie = 1;
ee_int_occ = FALSE;
if (gie) // if gie is enabled, turn it off
gie_flag = TRUE;
while(gie)
gie = 0;
gie_flag = FALSE;
wren = 1; // write enable
EECON2 = 0x55; // protection sequence
EECON2 = 0xaa;
wr = 1; // begin programming sequence
#ifdef EE_INT
gie = 1;
while(!ee_int_occ)
eeie = 0;
while(gie)
gie = 0;
#else
delay_ms(10);
wren = 0; // disable write enable
if (gie_flag)
gie = 1;
while(gie)
gie = 0;
Peter H Anderson, <a href="http://www.phanderson.com," TARGET="_blank">http://www.phanderson.com,</a> pha(at)phanderson.com
:=I program my 18f452 with PCH 3.06. I had downloaded The suggested solution form mark and use in my program. Unfortunately it still doesn't work. The EEDATA always hold the last written value when we try to read back the eeprom contain.
:=Attached is a code of mine, can you kindly consult me where is the problem?
:=Thanks & regards,
:=Law
:=///my program///
:=#include <18f452.h>
:=#fuses xt,noprotect,nowdt,put,brownout,nolvp
:=#use delay(clock=4000000)
:=#use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
:=//--------------------------- old version -------------------------------------
:=#define EEADR 0xFA9
:=#define EEDATA 0xFA8
:=#define EECON1 0xFA6
:=#define RD 0
:=#define WR 1
:=#define WREN 2
:=#define WRERR 3
:=#define FREE 4
:=#define CFGS 6
:=#define EEPGD 7
:=#define EECON2 0xFA7
:=#define PIR2 0xFA1
:=#define EEIF 4
:=void writeeeprom(int address, int data)
:=bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
:=(int)*EEADR = address; // Load our address
:=(int)*EEDATA = data; // Load our data
:=bit_clear(*EECON1, EEPGD); // Point to data memory
:=bit_set(*EECON1, WREN); // Enable writes
:=// Microchip recommends disabling ints here
:=disable_interrupts(GLOBAL);
:=(int)*EECON2 = 0x55; // Write 0x55
:=(int)*EECON2 = 0xAA; // Write 0xAA
:=bit_set(*EECON1, WR); // Set WR to begin write
:=// Ok to turn back on ints
:=enable_interrupts(GLOBAL);
:=// Wait for the write to complete
:=while (!bit_test(*PIR2, EEIF));
:=bit_clear(*EECON1, WREN); // disable writes
:=int readeeprom(int address)
:=bit_set(*EECON1, RD); // EEPROM Read
:=return(*EEDATA); // Return with our value
:=main()
:={ int8 ctr, ctr2, ctr3,i;
:=SET_UART_SPEED(19200);
:=for(ctr = 100; ctr<=110; ctr++)
:=ctr2 = ctr - 100 + 1;
:=writeeeprom(ctr, ctr2);
:=ctr = 100;
:=while(1)
:=putc(13);
:=ctr3 = readeeprom(ctr);
:=printf("addr = \%u eep = \%u", ctr,ctr3);
:=if(ctr<110)
:=ctr++;
:=else
:=ctr=100;
:=delay_ms(600);
Original Post ID: 6321
Mark
PostPosted: Tue Aug 13, 2002 1:58 pm     Reply with quote
I compiled this with 3.085 and everything seems okay (running on an ice2000). Here is the lst file. Note that I commented out the printf since I was not connected to a PC. Instead, I read the EEPROM and checked the value of ctr3 after each read.
0000: GOTO 0084
.................... ///my program///
.................... #include <18f452.h>
.................... //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
.................... #list
.................... #fuses xt,noprotect,nowdt,put,brownout,nolvp
.................... #use delay(clock=4000000)
0054: CLRF FEA
0056: MOVLW 0B
0058: MOVWF FE9
005A: MOVF FEF,W
005C: BTFSC FD8.2
005E: GOTO 0080
0062: MOVLW 01
0064: MOVWF 01
0066: CLRF 00
0068: DECFSZ 00,F
006A: BRA 0068
006C: DECFSZ 01,F
006E: BRA 0066
0070: MOVLW 4A
0072: MOVWF 00
0074: DECFSZ 00,F
0076: BRA 0074
0078: NOP
007A: NOP
007C: DECFSZ FEF,F
007E: BRA 0062
0080: GOTO 0102 (RETURN)
.................... #use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
.................... //--------------------------- old version -------------------------------------
.................... #define EEADR 0xFA9
.................... #define EEDATA 0xFA8
.................... #define EECON1 0xFA6
.................... #define RD 0
.................... #define WR 1
.................... #define WREN 2
.................... #define WRERR 3
.................... #define FREE 4
.................... #define CFGS 6
.................... #define EEPGD 7
.................... #define EECON2 0xFA7
.................... #define PIR2 0xFA1
.................... #define EEIF 4
.................... void writeeeprom(int address, int data)
.................... bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
0004: BCF FA1.4
.................... (int)*EEADR = address; // Load our address
0006: MOVFF 0A,FA9
.................... (int)*EEDATA = data; // Load our data
000A: MOVFF 0B,FA8
.................... bit_clear(*EECON1, EEPGD); // Point to data memory
000E: BCF FA6.7
.................... bit_set(*EECON1, WREN); // Enable writes
0010: BSF FA6.2
.................... // Microchip recommends disabling ints here
.................... disable_interrupts(GLOBAL);
0012: BCF FF2.6
0014: BCF FF2.7
0016: BTFSC FF2.7
0018: GOTO 0014
.................... (int)*EECON2 = 0x55; // Write 0x55
001C: MOVLW 55
001E: MOVWF FA7
.................... (int)*EECON2 = 0xAA; // Write 0xAA
0020: MOVLW AA
0022: MOVWF FA7
.................... bit_set(*EECON1, WR); // Set WR to begin write
0024: BSF FA6.1
.................... // Ok to turn back on ints
.................... enable_interrupts(GLOBAL);
0026: MOVLW C0
0028: IORWF FF2,F
.................... // Wait for the write to complete
.................... while (!bit_test(*PIR2, EEIF));
002A: BTFSS FA1.4
002C: GOTO 002A
0030: GOTO 0034
.................... bit_clear(*EECON1, WREN); // disable writes
0034: BCF FA6.2
0036: BCF FA1.4
0038: GOTO 00C2 (RETURN)
.................... int readeeprom(int address)
003C: MOVFF 0A,FA9
0040: BCF FA6.7
.................... bit_set(*EECON1, RD); // EEPROM Read
0042: BSF FA6.0
0044: MOVFF 0A,FA9
0048: BCF FA6.7
004A: BSF FA6.0
.................... return(*EEDATA); // Return with our value
004C: MOVF FA8,W
004E: MOVWF 01
0050: GOTO 00DE (RETURN)
.................... main()
.................... { int8 ctr, ctr2, ctr3,i;
0084: CLRF FEA
0086: CLRF FE9
0088: CLRF FC1
008A: CLRF 05
008C: MOVLW 19
008E: MOVWF FAF
0090: MOVLW 26
0092: MOVWF FAC
0094: MOVLW 90
0096: MOVWF FAB
.................... SET_UART_SPEED(19200);
0098: MOVLW 0C
009A: MOVWF FAF
009C: MOVLW 26
009E: MOVWF FAC
.................... for(ctr = 100; ctr<=110; ctr++)
00A0: MOVLW 64
00A2: MOVWF 06
00A4: MOVF 06,W
00A6: SUBLW 6E
00A8: BTFSS FD8.0
00AA: GOTO 00C8
.................... ctr2 = ctr - 100 + 1;
00AE: MOVLW 64
00B0: SUBWF 06,W
00B2: ADDLW 01
00B4: MOVWF 07
.................... writeeeprom(ctr, ctr2);
00B6: MOVFF 06,0A
00BA: MOVFF 07,0B
00BE: GOTO 0004
00C2: INCF 06,F
00C4: GOTO 00A4
.................... ctr = 100;
00C8: MOVLW 64
00CA: MOVWF 06
.................... while(1)
.................... putc(13);
00CC: MOVLW 0D
00CE: BTFSS F9E.4
00D0: GOTO 00CE
00D4: MOVWF FAD
.................... ctr3 = readeeprom(ctr);
00D6: MOVFF 06,0A
00DA: GOTO 003C
00DE: MOVFF 01,08
.................... //printf("addr = \%u eep = \%u", ctr,ctr3);
.................... if(ctr<110)
00E2: MOVF 06,W
00E4: SUBLW 6D
00E6: BTFSS FD8.0
00E8: GOTO 00F2
.................... ctr++;
00EC: INCF 06,F
.................... else
00EE: GOTO 00F6
.................... ctr=100;
00F2: MOVLW 64
00F4: MOVWF 06
.................... delay_ms(600);
00F6: MOVLW 03
00F8: MOVWF 0A
00FA: MOVLW C8
00FC: MOVWF 0B
00FE: GOTO 0054
0102: DECFSZ 0A,F
0104: BRA 00FA
0106: GOTO 00CC
010A: SLEEP
Mark
:=Thanks & regards,
:=Law
:=///my program///
:=#define RD 0
:=#define WR 1
:=#define WREN 2
:=#define WRERR 3
:=#define FREE 4
:=#define CFGS 6
:=#define EEPGD 7
:=#define EEIF 4
:=main()
:=ctr = 100;
:=while(1)
:=putc(13);
:=if(ctr<110)
:=ctr++;
:=else
:=ctr=100;
:=delay_ms(600);
Original Post ID: 6348
PostPosted: Wed Oct 16, 2002 1:50 am     Reply with quote
I had the same problem: writing nor reading to and from the EEPROM did work. (18f452)
Now I 'manually' clear the CFGS bit in EECON1 (FA6h)
#ASM
bcf EECON1,6 // solve bug
#ENDASM
And it works!
BTW: I'm using v3.089 and I think this bug is solved in later updates, but my support has run out.
Thanks Peter!
Original Post ID: 7870
