unions of structs...
kernel panic
PostPosted: Thu Aug 01, 2002 2:48 pm     Reply with quote
im trying to create a structure for peeling apart a 16b command word.. why doesn't this work??
struct __commandstruct
byte C0:1;
byte uu:4;
byte Ps:3;
byte timerval;
union
__commandstruct commandstruct;
long commandword;
i should then be able to get the elements like so..
comamandword= 0xffff;
commandstruct.CO=false
etc..
it no work like that?? as far as i can tell its of the txtbook..
____
Original Post ID: 6014
kernel panic
Re: unions of structs...
PostPosted: Thu Aug 01, 2002 3:02 pm     Reply with quote
it seems nesting the struct inside the union works.. perhaps the compiler doesn't like previously defined typedefs inside of new typedefs..
:=im trying to create a structure for peeling apart a 16b command word.. why doesn't this work??
:=struct __commandstruct
:= byte C0:1;
:= byte uu:4;
:= byte Ps:3;
:= byte timerval;
:=union
:= __commandstruct commandstruct;
:= long commandword;
:=i should then be able to get the elements like so..
:=comamandword= 0xffff;
:=commandstruct.CO=false
:=etc..
:=it no work like that?? as far as i can tell its of the txtbook..
:= ____
Original Post ID: 6015
Woody
PostPosted: Wed Aug 07, 2002 1:53 am     Reply with quote
Your example code does not use typedef to define a new user type and therefore your union should look like this:-
union
struct __commandstruct commandstruct;
long commandword;
The following example shows two ways of defining the structure and overlay. Either method will work but using typedef's is usually easier.
#include <16f876.h>
#pragma CASE
#define FIRST_METHOD
#ifdef FIRST_METHOD
#define DATA_OVERLAY_TYPE Datamap
typedef struct tagCommandstruct {
unsigned int C0:1;
unsigned int uu:4;
unsigned int Ps:3;
unsigned int timerval;
} Commandstruct;
/* Example 1 using newly defined type */
typedef union tagDatamap {
Commandstruct commandstruct;
long commandword;
} Datamap;
#else
#define DATA_OVERLAY_TYPE union tagDatamap
unsigned int C0:1;
unsigned int uu:4;
unsigned int Ps:3;
/* Example 2 using struct tagCommandstruct */
union tagDatamap {
struct tagCommandstruct commandstruct;
long commandword;
int main (void)
DATA_OVERLAY_TYPE v;
v.commandstruct.C0 = 1;
PS.
It's not a good idea to use identifiers starting underscore. I believe the ANSI standard for 'C' reserves identifiers starting with double underscore __ and underscore following by a capital letter. That's not to say user identifiers defined like this this will not work, but it could easily cause an obscure problem one day.
Original Post ID: 6134
