Need Help with Long Int
Eric Bauer
PostPosted: Fri Oct 05, 2001 1:56 pm     Reply with quote
Hello Everyone,
The following is a code snip from a project I'm working on. I hope someone can tell me why the printf statement in the main function reports that my long int 'x_delay' is some negative number like -3438 after I have expicitly set it to 62000??
Looking for help,
Eric
P.S. Using comiler PCM 2.734
// xy_table.c --
// INCLUDE FILES
#include <16f876.H>
// COMPILER AND CHIP CONFIGURATION DIRECTIVES
#fuses RC, NOWDT, NOPROTECT, NOBROWNOUT
#use Delay(Clock=4000000) // We're using a 4 MHz crystal
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7) // Use built-in USART
#priority timer1,rda
// DEFINITIONS
#define RECV_FIFO_SIZE 30
// GLOBAL VARIABLES
char recv_fifo[RECV_FIFO_SIZE]; // Fifo for the RS-232 receive data isr
char *recv_fifo_head; // Pointers for the recv fifo
char *recv_fifo_tail;
char recv_fifo_byte_count; // Number of bytes in the recv fifo
// My Globals
char CmdArray[RECV_FIFO_SIZE]; // Array for storing commands from PC
int index=0; // Index of array storing serial commads B4 parsing
long x_dist=0; // X Axis Distance(steps)
long x_delay=62000; // X Axis Step Delay--Delay between steps
// FUNCTION DECLARATIONS
void init_rs232_recv_buffer(void);
char get_rs232_char(void);
char is_rs232_char_ready(void);
void rs232_recv_data_isr(void);
void move_x(void); //ISR for X Axis step code
long ConvertToLong(*string,len); //Converts ascii number to long int
int ConvertToInt(*string,len); //Convert ascii number to int
//====================== Main Function ================================================
char value;
printf("Delay at Start=\%ld\n\r",x_delay);
init_rs232_recv_buffer(); // Init pointers to recv fifo
setup_timer_1(T1_Internal|T1_DIV_BY_1);
set_timer1(x_delay);
//enable_interrupts(INT_TIMER1); //will interrupt processor and run code to step motor
if(is_rs232_char_ready() == TRUE) // Did we receive an RS-232 char ?
value = get_rs232_char(); // If so, get the byte
putc(value); // echo it back to host
Original Post ID: 552
Richard Henry
Re: Need Help with Long Int
PostPosted: Fri Oct 05, 2001 2:12 pm     Reply with quote
Try unsigned long.
:=Hello Everyone,
:=The following is a code snip from a project I'm working on. I hope someone can tell me why the printf statement in the main function reports that my long int 'x_delay' is some negative number like -3438 after I have expicitly set it to 62000??
Original Post ID: 553
DominicB
PostPosted: Fri Oct 05, 2001 2:38 pm     Reply with quote
Try using \%lu instead of \%ld, 'd' stands for signed int while 'u' is unsigned.
Best regards
:=Hello Everyone,
:=Looking for help,
:=Eric
:=P.S. Using comiler PCM 2.734
:=// xy_table.c --
:=// INCLUDE FILES
:=#include <16f876.H>
:=// COMPILER AND CHIP CONFIGURATION DIRECTIVES
:=#fuses RC, NOWDT, NOPROTECT, NOBROWNOUT
:=#use Delay(Clock=4000000) // We're using a 4 MHz crystal
:=#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7) // Use built-in USART
:=#priority timer1,rda
:=// DEFINITIONS
:=#define RECV_FIFO_SIZE 30
:=// GLOBAL VARIABLES
:=char recv_fifo[RECV_FIFO_SIZE]; // Fifo for the RS-232 receive data isr
:=char *recv_fifo_head; // Pointers for the recv fifo
:=char *recv_fifo_tail;
:=char recv_fifo_byte_count; // Number of bytes in the recv fifo
:=// My Globals
:=char CmdArray[RECV_FIFO_SIZE]; // Array for storing commands from PC
:=int index=0; // Index of array storing serial commads B4 parsing
:=long x_dist=0; // X Axis Distance(steps)
:=long x_delay=62000; // X Axis Step Delay--Delay between steps
:=// FUNCTION DECLARATIONS
:=void init_rs232_recv_buffer(void);
:=char get_rs232_char(void);
:=char is_rs232_char_ready(void);
:=void rs232_recv_data_isr(void);
:=void move_x(void); //ISR for X Axis step code
:=long ConvertToLong(*string,len); //Converts ascii number to long int
:=int ConvertToInt(*string,len); //Convert ascii number to int
:=//====================== Main Function ================================================
:=void main(void)
:=char value;
:=printf("Delay at Start=\%ld\n\r",x_delay);
:=init_rs232_recv_buffer(); // Init pointers to recv fifo
:=setup_timer_1(T1_Internal|T1_DIV_BY_1);
:=set_timer1(x_delay);
:=//enable_interrupts(INT_TIMER1); //will interrupt processor and run code to step motor
:=while(1)
:= if(is_rs232_char_ready() == TRUE) // Did we receive an RS-232 char ?
:= value = get_rs232_char(); // If so, get the byte
:= putc(value); // echo it back to host
Original Post ID: 554
