translate string number to unsigned long
rvdbogae
PostPosted: Wed Apr 24, 2002 2:22 am     Reply with quote
Hi All
I try to read an unsigned long via the RS232 into my pic.
I dont know how to do.
In the following code I read a sting (number) into my pic (16F877).
Is it possible to translate it in a unsigned long?
Are there other (more simple) possebilities?
////////////////code/////////////////////////////////////
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=20000000)
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7)
main() {
char string[50];
printf("give the number of pulses\r\n");
gets(string);
printf("\%S\n", string);
//// now translate string to unsigned long
thanks for help,
ruud
Original Post ID: 3976
Hans Wedemeyer
Re: translate string number to unsigned long
PostPosted: Wed Apr 24, 2002 7:08 am     Reply with quote
If it is an ASCII string the simply use the atoi(&string); function.
If you simply want to receive the bytes directly as binary values, then put them into a struct/union one by one and you do not have to convert anything.
Example:-
struct HighLow
char l;
char h;
union HL
long L;
struct HighLow hl;
union HL MyNumber;
MyNumber.hl.h = getchar(); // receive the high byte first
MyNumber.hl.l = getchar(); // receive the low byte next
Now you have the unsigned long value as MyNumber.L and no conversion needed.
unsigned long XYZ = MyNumber.L;
Then when you need to send it back out simply do this:-
putchar(MyNumber.hl.h);
putchar(MyNumber.hl.l);
:=////////////////code/////////////////////////////////////
:=#fuses HS,NOWDT,NOPROTECT
:=#use delay(clock=20000000)
:=#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7)
:=main() {
:= char string[50];
:= printf("give the number of pulses\r\n");
:= gets(string);
:= printf("\%S\n", string);
:= while(1);
:= //// now translate string to unsigned long
:=thanks for help,
:= ruud
Original Post ID: 3981
Todd C. Micallef
PostPosted: Wed Apr 24, 2002 11:08 am     Reply with quote
Another way to convert is to use the get_long()function in the input.c file inside the drivers dir. The function defaults to returning a signed value though.
:=Hi All
:=I try to read an unsigned long via the RS232 into my pic.
:=I dont know how to do.
:=In the following code I read a sting (number) into my pic (16F877).
:=Is it possible to translate it in a unsigned long?
:=Are there other (more simple) possebilities?
:=main() {
:= char string[50];
:= gets(string);
:= while(1);
:=thanks for help,
:= ruud
Original Post ID: 3986
