John Kennedy Guest
| Output Pin Oscillating |
Posted: Tue Nov 06, 2001 10:12 am |
I have written my 2nd Program for the 16C710 and have encountered output pins oscillating when given the output_low or output_high command. I have 10K pullups to the 5V rail on each pin. I'm using a 200Khz RC Oscillator the frequency the output pins oscillate at is 3.9Khz does anyone have any idea how to correct this. I have included a portion of the code that I have used to see if you can spot what I'm missing.
#define connect 125
#define vmin 50
#define minamp 3
#define almost 72
int batt,volt,amp;
int charged();
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
start:
output_high(PIN_B1);
output_high(PIN_B2);
output_high(PIN_B3);
output_high(PIN_B4);
output_high(PIN_B5);
output_low(PIN_B6); //pin works as it should here
do
set_adc_channel(0);
delay_us(100);
batt = read_adc();
while (batt > connect);
output_high(PIN_B6);
do
set_adc_channel(1);
delay_us(100);
volt = read_adc();
while (volt < vmin);
//all these pins oscillate at this point
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B4);
Any help appreciated
John Kennedy
Original Post ID: 982 |
| Re: Output Pin Oscillating |
Posted: Tue Nov 06, 2001 1:23 pm |
:=I have written my 2nd Program for the 16C710 and have encountered output pins oscillating when given the output_low or output_high command.
What do you have connected to each of the port B pins ?
(list all components).
Original Post ID: 986 |
John Kennedy Guest
Posted: Wed Nov 07, 2001 2:11 am |
:=I have written my 2nd Program for the 16C710 and have encountered output pins oscillating when given the output_low or output_high command. I have 10K pullups to the 5V rail on each pin. I'm using a 200Khz RC Oscillator the frequency the output pins oscillate at is 3.9Khz does anyone have any idea how to correct this. I have included a portion of the code that I have used to see if you can spot what I'm missing.
:=#define connect 125
:=#define vmin 50
:=#define minamp 3
:=#define almost 72
:=int batt,volt,amp;
:=int charged();
:=void main() {
:= setup_adc_ports(ALL_ANALOG);
:= setup_adc(ADC_CLOCK_DIV_2);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:=start:
:= output_high(PIN_B1);
:= output_high(PIN_B2);
:= output_high(PIN_B3);
:= output_high(PIN_B4);
:= output_high(PIN_B5);
:= output_low(PIN_B6); //pin works as it should here
:= do
:= set_adc_channel(0);
:= delay_us(100);
:= batt = read_adc();
:= while (batt > connect);
:= output_high(PIN_B6);
:= do
:= set_adc_channel(1);
:= delay_us(100);
:= volt = read_adc();
:= while (volt < vmin);
:=//all these pins oscillate at this point
:= output_low(PIN_B1);
:= output_low(PIN_B2);
:= output_low(PIN_B4);
:=Any help appreciated
:=Thanks
:=John Kennedy
I don't have anything at the moment only a 10K pullup resistor to the 5V rail. I'm just testing the program to get it to do what I want it to. When it works the pins will be connected as follows.
RB1 - series 4k7 resistor to a gate of a 2N7000 signal mosfet.
RB2 - connected to the reset pin of a HEF4521 binary counter.
RB3 - connected to the output pin of the HEF4521.
RB4 - Cathode of an LED(LED on when pin low).
RB5 - as RB4.
All other pins floating.
If you can see any other potential problems please let me know.
Original Post ID: 995 |
Sherpa Doug Guest
Posted: Wed Nov 07, 2001 8:17 am |
Is your +5 supply stable? Maybe one of these outputs is shorted to +5, or one of the pullups is much smaller than 10k, and the output going low causes the processor to hiccup. Try only setting one pin at a time to see which one is the culprit.
Original Post ID: 1000 |
