Posted: Fri Aug 29, 2014 7:04 pm |
This website has messages to turn on/off various Ublox messages:
http://www.zeedless.com/articles.html
This website also has useful information:
http://ukhas.org.uk/guides:ublox6
Example:
| Code: | NMEA Message - RMC
$PUBX,40,RMC,0,0,0,0*47 // Turn OFF
$PUBX,40,RMC,1,1,1,0*46 // Turn ON
You could send the message from your PIC to the UBlox GPS
with this statement:
| Code: | | printf("$PUBX,40,RMC,1,1,1,0*46\r\n"); // Turn ON GPRMC |
tatoo
| problem with ublox gps |
Posted: Sat Aug 30, 2014 7:05 am |
I use the | Code: | | $PUBX,40,RMC,1,1,1,0*46 // Turn ON |
but i still can not see the RMC .
the code which i use is :
enable_interrupts(INT_RDA2);
//printf("$PUBX,40,RMC,1,1,1,0*46\r\n");
if (GPSDataReady)
fprintf(PC,"DATA:%s\n",GPSData);
GPSDataReady = FALSE;
what is wrong ? |
Posted: Sat Aug 30, 2014 7:44 am |
1. It's possible that you don't have the correct connections between the
PIC serial port and the GPS.
2. You may not have a Ublox GPS chip, or the model that you have may
not respond to the PUBX commands.
3. You may have a defective GPS chip.
4. You may have a counterfeit GPS chip that you bought on eBay
and it just doesn't work correctly. This can happen on eBay. |
ezflyr
Posted: Sat Aug 30, 2014 11:51 am |
It's possible that you are trying to send configuration data to the GPS module too soon? Most GPS modules have a start-up sequence and are not ready to receive data immediately. A number of my projects receive NMEA data from a GPS module (various types, but mostly USGlobalSat SiRF chipset), and I send the configuration data to the GPS about 4 seconds after power on. During this time I'm doing some other start-up tasks, and when they are done, I configure the GPS, and then enable the #int_rda interrupt. Try to add some delay before sending the GPRMC On command, and do this all before enabling the Rx interrupt.
John |
tatoo
Posted: Sun Aug 31, 2014 12:48 pm |
I suspect that the problem is that i can receive data from the gps but i can not sent data to the gps .
so i can not sent the
ezflyr
Posted: Sun Aug 31, 2014 1:39 pm |
It could be a hardware problem, or you could be sending the wrong commands. Really impossible to tell as you never provided the documentation for the actual module you are using. At the point, the best we can do is make educated guesses.... I really have no clue why you want to handicap yourself, and us, like that?
John |
tatoo
Posted: Sun Aug 31, 2014 4:20 pm |
Ok...while I'm waiting for your files to download...
Do this simple test
Cut code to allow the PC KBD to send data to the PIC,receive it, send out to the 'GPS comport' loopback via a wire, receive the 'GPS data' then send it to the PC screen.
This simple,basic test will confirm whether the PIC and hardware is working OK.
No ISRs, just simple getc() and putc() functions will do.
so
recode/recompile/retest/report back
hth
jay |
Posted: Sun Aug 31, 2014 4:37 pm |
sigh... no wonder WHY you're having problems if that dotRAR is the sum total of information you have !
arrgh..
two problems I can see
1) you MUST wait for at least 30 seconds BEFORE trying to access the GPS. OK, the datasheet say 26, but really wait 30.
2) that 'ardunio shield' appears to have a voltage divider in the RX line.If true then the data from the GPS only goes up to 1.5 volts , not enough for the 3V PIC to recognize as a logic level '1'.
My 'hunch' is that #2 is your main probelm, #1 is easily fixed, just add a delay_ms(30000) in main() during your PIC initalization.
also....
use rs232(...) functions normally require a MAX232 type device , yet the GPS is a LVTTL type so ou may need to invert the data. Just an idea...without chips and scope I can't tell for sure...
hth
jay |
Posted: Sun Aug 31, 2014 4:47 pm |
The schematic shows a voltage divider consisting of R1 and R3. This
voltage divider will reduce the input voltage to the UBlox RX pin by 50%.
However, there's a problem. We still don't know for sure what UBlox
chip you are using. You gave us the data sheet for the Neo-6, but the
schematic shows a Neo-5Q. And, they have different specs for the Rx
input voltage levels. The Neo-6 data sheet shows Vih is 0.7 * Vdd
which is 2.31 volts. But the Neo-5Q data sheet has a separate spec
for the RxD1 pin. The Vih is 0.91 volts.
Conclusion: If that is really the schematic of your board, and if you
really have the Neo-5Q, then it should work with your dsPIC33.
But, if you are using that schematic, but instead with a Neo-6, the
voltage divider will reduce the signal level to 1.65 volts, and that's
not going to work with the Rx pin on the Neo-6.
So again, as we said over and over to you, we must have full disclosure
of all the facts. What board do you have ? Does your posted schematic
match that board ? And what UBlox chip do you have on the board ?
Until you answer these questions we can't do anything. |
tatoo
Posted: Sun Aug 31, 2014 4:52 pm |
I can clearly read from the chip :
NEO-6M-0-001
so the chip is the NEO-6M.
At the board there is a switch(for choose 3.3V or 5V) as input. So the power supply of 3.3V is ok . |
Posted: Sun Aug 31, 2014 5:00 pm |
and... to add further confusion..
the GPS data output (pin 20[information FROM the GPS]) is labelled RX becomes the Ardunio shield internal label TXD which the user configures to a real micro pin.....
things were a LOT simpler with RS-232 !!
jay |
ezflyr
Posted: Sun Aug 31, 2014 5:58 pm |
So, you need to eliminate the voltage divider on the GPS Rx input if you are using the Neo-6 GPS module. Remove the resistor connected to Gnd, and short out the series one. Test, and report back.
John |
ezflyr
Posted: Tue Sep 02, 2014 1:28 pm |
[Rant]
I guess it should not bother me, but I find it extremely discourteous when someone comes here to the forum, asks for our help, takes part in a back-and-forth exchange of ideas toward a solution, and then - POOF! - suddenly disappears without so much as a status report, a simple thank you, or even an FU.
I'm going to start putting some of these jokers on my 'do not respond' list!
[/Rant]
John |
tatoo
Posted: Tue Sep 02, 2014 2:58 pm |
ezflyr i try to find a solution for the resistor.
(The smd components is not my favorite so ... )
Do you think is a good idea to buy another gps (NEO-6m) module (only with gps module without sd card) ?
If yes, can you suggest where can i buy (except ebay ) |
