Posted: Thu Jun 09, 2016 12:39 am |
'RESTART_TRAP_CONFLICT', is what you get, if you don't have a handler for the error. When this happens, the stack/trapaddr is lost.
You need to have the handler:
unsigned long trapaddr;
#INT_ADDRERR
void ADDRERR_isr(void)
#asm
mov w15, w0
sub #38, w0
mov [w0++], w1
mov w1, trapaddr
mov [w0], w1
and #0x7f, w1
mov w1, trapaddr+2
#endasm
clear_interrupt(INT_ADDRERR);
restart_cpu(); //This causes a _software reset_.
This then means you then soft reboot, with the value stored in 'trapaddr'.
Then check for 'RESTART_SOFTWARE', and see what is in trapaddr. |
younder
Posted: Fri Jun 10, 2016 11:15 am |
Hi Ttelmah,
I have the trap routine handler already in my code (Same as yours posted on this tread Fri Jul 24, 2015 1:58 am), except for the two new lines below:
Without these two lines, the MCU is restarting and calling 'RESTART_TRAP_CONFLICT'.
I'll test it again to see if it will works now.
Thanks buddy
Hugo _________________ Hugo Silva |
younder
Posted: Fri Jun 10, 2016 3:31 pm |
Now I have changed my ISR trap handler to:
#INT_ADDRERR
#asm
mov w15, w0
sub #38, w0
mov [w0++], w1
mov w1, trapaddr
mov [w0], w1
and #0x7f, w1
mov w1, trapaddr+2
#endasm
reset_cpu(); //This causes a _software reset_.
And I still get 'RESTART_TRAP_CONFLICT', but this time with trapaddr=8C06188D (coud not find this address in the .LST!)
The Point is that if I compile my code with CCS V5.051 there is no trap conflict! .... would that be a compiler (5.059) bug? _________________ Hugo Silva |
younder
Posted: Tue Jun 21, 2016 5:29 pm |
Finnaly I've found that the trap conflict was due to a compiler (v5.059) bug when copying an array element from one array to another
when the source is a structure declared as 'const'....
http://www.ccsinfo.com/forum/viewtopic.php?t=55193
This is why I was not able to see the err_addr after mcu is reset.
