solved: Bootloader - remove or relocate startup code
Goto page Previous  1, 2
PostPosted: Sat Sep 26, 2026 11:02 am     Reply with quote
Er.
For PCH (PIC18), needs to be:
#fuses NONE
#build (reset=0x800, interrupt=0x0808)
#org 0x0000, 0x07FF{}
The loader_end+5 address is for PCM (PIC16's).
vtrx
PostPosted: Fri Oct 02, 2026 6:09 pm     Reply with quote
I'm having a problem with the low-priority interrupt.
It isn't executing as it should.
#define APP_INICIO   0x10C0
#build (reset=APP_INICIO, interrupt=APP_INICIO + 0x0008)
//#build(reset=0x10C0:0x10C7, interrupt=0x10C8:0x10FF)
#org 0x0000,APP_INICIO - 1{}
In the bootloader:
#define ENDERECO_APP 0x10C0
#define FLASH_FIM   0x8000   // p
#int_global
void high_isr_vector(void)
   #asm
   //GOTO ENDERECO_APP + 0x0008  //
   GOTO 0x10C8
   #endasm
#org 0x0018, 0x0027
void low_isr_vector(void)
    #asm
    //GOTO ENDERECO_APP + 0x018   //
    GOTO 0x10D8
    #endasm
The registers are programmed with the correct values; the problem lies in the main application—it seems CCS isn't routing low-priority interrupts correctly.
vtrx
PostPosted: Sat Oct 03, 2026 6:44 pm     Reply with quote
I decided to place the bootloader at the end of the flash memory; this way, the main application can be compiled normally without modifications, making things easier.
Page 2 of 2
