Posted: Mon Apr 01, 2019 3:59 pm |
If you use quotes like below, the compiler will try to get the file
from your project files folder:
| Code: | | #include "string.h" |
If you use angle brackets like below, it will get string.h from
the CCS drivers folder (the 5.078 version).
| Code: | | #include <string.h> |
So use angle brackets. |
Gabriel
Posted: Mon Apr 01, 2019 8:13 pm |
Did that... still loaded from 5.013 _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Mon Apr 01, 2019 9:11 pm |
Another way is use quotes, and specify the full complete path to the
desired file. |
Gabriel
Posted: Tue Apr 02, 2019 11:53 am |
I still can get this code to compile due to the missing #endif - Which im not missing.
what could cause this error or how can i track it down.
I've started injecting random errors around the code to see where the compiler fails first due to my induced code error over the missing endif... but the results are ambiguous... I get errors in functions that have not changed in years, and even after an inspection i cant seem to find any thing wrong.
This has got me thinking the error might be in one of the standard library files but that isnt likely.
I did find a case mismatch on an #ifdef ending in a #ENDIF but that didnt solve anything on String.h _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue Apr 02, 2019 12:04 pm |
Can you post a list of all the CCS provided source files (.c, .h)
that you are #including in your program ?
String.h ends like this:
Is it possible that you edited the file and assumed that the asterisk line
was the end, and you chopped off the #endif ? |
Gabriel
Posted: Tue Apr 02, 2019 12:18 pm |
Only these 2:
#include "C:\Program Files (x86)\PICC - 5.078\Drivers\string.h"
#include "C:\Program Files (x86)\PICC - 5.078\Drivers\stdlib.h"
| Quote: | /************************************************************/
#endif |
This is the end of the file as you described. i have not touched these files in any way EXCEPT changing 1 #ENDIF to #endif thinking it could be case mismatch... that had no effect like i mentioned earlier.
Most of the code im using its at least 2 or 3 years old... the code compiles fine in 5.013. i seriously doubt there is an #endif missing as i dont use them that frequently. i think something else is triggering this error. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue Apr 02, 2019 12:33 pm |
I can offer to look at it. You could zip up the project folder, post it to
Google Drive or something, with a password. Then give me the link
and the password in a PM. But, this may not be possible due to
an NDE from the customer.
So maybe I could list what I would do to find the problem. I will have
to think about what I would do. |
Gabriel
Posted: Tue Apr 02, 2019 12:49 pm |
yeah... I cant disclose the code.
Well ill try to fix the phantom calls using 5.013 by moving code around, smaller functions and the likes... see if that solves the issue in 5.078.
I think this is the same problem, just a different response in each compiler. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue Apr 02, 2019 1:22 pm |
Here is what I would do:
1. Zip up the project directory to preserve it. I want to be able
to freely "mess up" the source files without having to worry about
putting them back together later. The zip file will do that.
2. Put a text statement at the start of every source file, using a
pre-processor statement, to state the name of the file.
Then compile, and look in the Build output window. Confirm that
all files are listed there. This is done to check if some obscure old
file in a different folder is being accidently included and messing you
up. This old file might have a dangling #if statement in it.
3. Start commenting out driver files, one by one. Say you have ds1307.c
in your program. Comment out the #include line for it. Also comment
out any lines in your main or other source files that call its functions.
You may find the culprit by this method. Or all that's left may be
your main C source file. Also comment out .h files such as string.h
and comment out the lines in main.c that call those functions. Really
get in there and cut. |
Posted: Wed Apr 03, 2019 12:54 am |
With some help from CCS support, I was able to duplicate this error:
| Quote: |
>>> Warning 236 "C:\Program Files (x86)\PICC - PCH - 5.013
\drivers\string.h" Line 54(9,16): Defined identifier matches a variable ID |
Here is a test program that generates the error:
| Code: | #include <18F87J50.h>
#fuses NOWDT
#use delay(crystal=20M)
int8 strcopy;
#include <string.h>
while(TRUE);
The error occurs because CCS has this line in string.h:
| Quote: | | #define strcopy strcpy |
Somewhere in your source files, you have declared 'strcopy' as a variable.
Do a text search for strcopy in all your source files. If you find
a line where it's declared as a variable, change the name to something
unique. MPLAB has a "Find in Files" feature in the Edit menu to do this search.
It could be that one of these warnings is somehow implicated in the
#endif problem. So fix all these too:
| Quote: | | >>> Warning 230 Line 660(1,1): String truncated |
This warning is caused by declaring an array that is too small to hold
the string. Example:
| Code: | | int8 msg[6]={"Hello World"}; |
| Quote: | | >>> Warning 203 Line 74(1,1): Condition always TRUE |
This warning is usually caused by using while(1) instead of while(TRUE).
It could also be caused by an expression in an if() statement or a for()
loop that evaluates to always be TRUE. |
Posted: Wed Apr 03, 2019 3:08 am |
Can I make a suggestion.
I've had issues like this in the past, and simple text searches are the place
to start.
So, if you have the IDE, select 'find in files'. Then 'files in project', then
type #IF, and do a search. Then go to the results screen, and select
everything. Copy. Paste this into an empty text document.
Then repeat this, searching for #ENDIF. Paste the results of this into a
second text document.
Now look at these side by side.
How many lines do they both have?.
There may well be differences (for instance, the USB drivers have a few
places with #IF statements 'remmed' out), so you will find lines with
//#IF. These obviously don't have matching #ENDIF's. However if you
look at how many lines are in each file with matching 'file location'
entries, it gives you a very strong place to start looking. For instance
doing this on a small project here, I have ten lines in the #IF file
for a particular #include, and a matching ten lines in the #ENDIF
file. This allows you to reduce the number of places that need to
be actually inspected..... You can concentrate your search on the files
where there is an imbalance.  |
Gabriel
Posted: Thu Apr 04, 2019 11:08 am |
So, After extensive code commenting and going through what felt like thousands of un-comment/compile cycles the error is triggered by this:
| Code: | #ifndef CLOUD_WIFI
void UTF8_ENCODE(char symbol)
char Temp_string[]="x";
Temp_string[0]=symbol;
switch(symbol)
case '{':
strcat(Post_Buffer,"%7B");
case '}':
strcat(Post_Buffer,"%7D");
case '"':
strcat(Post_Buffer,"%22");
case ''':
strcat(Post_Buffer,"%27");
case ':':
strcat(Post_Buffer,"%3A");
case ',':
strcat(Post_Buffer,"%2C");
case '[':
strcat(Post_Buffer,"%5b");
case ']':
strcat(Post_Buffer,"%5d");
default:
strcat(Post_Buffer,Temp_string);
void CLEAR_POST()
memset(Post_Buffer,NULL,POST_BUFFER_SIZE); // Set all elements to NULL
Post_Buffer_Index=0; // Reset index
#endif |
These functions are declared on the driver file as follows:
| Code: | // Functions enabled if only using GPRS
#ifndef CLOUD_WIFI
#define UPLOAD 1
#define DOWNLOAD 0
#define POST_BUFFER_SIZE 400 //GPRS/WIFI - For all internet Connections
char Post_Buffer[POST_BUFFER_SIZE]; //GPRS/WIFI - For all internet Connections
int16 Post_Buffer_Index=0;
void UTF8_ENCODE(char);
void CLEAR_POST();
#endif |
The declaration does not cause the error, only the definition of the functions.
which are clearly NOT missing an #endif.
These 2 functions are part of my Wifi Driver, but in some cases when my device/application only has a GPRS connection, the GPRS driver checks to see if "CLOUD_WIFI" is defined and if not, it declares and defines the functions because they will be needed for GPRS.
maybe your eyes will see something im not seeing that may cause the #endif error, which somehow is not caused by a missing #endif. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Thu Apr 04, 2019 12:07 pm |
Related to previous responses:
This is caused by me purposely inserting a "\0" shorten a string.
| Code: | | Balance[(strlen(Balance))-1]="\0"; //There is an extra "." on the string we need to remove. |
| Quote: | Do a text search for strcopy in all your source files. If you find
unique. MPLAB has a "Find in Files" feature in the Edit menu to do this search. |
I did the search - No matches...
I have 2 while(1) which i've changed to TRUE - I didnt know it made a diference _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Thu Apr 04, 2019 12:37 pm |
I made a little test program, but unfortunately I don't get any errors when
compiled with vs. 5.078.
| Quote: | Compiling C:\Program Files\PICC\Projects\PCH_Test\PCH_Test on 04-Apr-19 at 11:33
Memory usage: ROM=0% RAM=11% - 12%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Thu Apr 04 11:33:30 2019 |
Test program:
#device PASS_STRINGS=IN_RAM
#fuses NOWDT
#include <string.h>
#ifndef CLOUD_WIFI
#define UPLOAD 1
#define DOWNLOAD 0
void CLEAR_POST();
#ifndef CLOUD_WIFI
switch(symbol)
case '{':
case '}':
case '"':
case ''':
case ':':
case ',':
case '[':
case ']':
default:
void CLEAR_POST()
char temp;
temp = '{';
UTF8_ENCODE(temp);
CLEAR_POST();
while(TRUE);
Gabriel
Posted: Thu Apr 04, 2019 12:45 pm |
As suggested by Ttelmah, did the #if/#endif Search - 31 matches for each. all corresponding to the right files and locations. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
