PIC16f1789 Crystal Mode
Goto page Previous  1, 2
hunter07
PostPosted: Wed Sep 27, 2017 12:09 pm     Reply with quote
I have updated the lst file..
blinking period is still ~19 sec
PostPosted: Wed Sep 27, 2017 12:13 pm     Reply with quote
What do you mean by "updated the lst file"?
hunter07
PostPosted: Wed Sep 27, 2017 12:22 pm     Reply with quote
I re-create the .lst file with Ttelmah code, as he suggested 3-4 message before
PostPosted: Wed Sep 27, 2017 12:28 pm     Reply with quote
...by recompiling the program? Sorry, it's just that I'm not 100% clear on whether you edited the lst file or you edited the program, which in turn generates the lst file.
hunter07
PostPosted: Wed Sep 27, 2017 12:53 pm     Reply with quote
Ttelmah wrote:
Compile the code as I posted it. Just change A0 to C7 for your LED.
You have added and duplicated several fuses, and removed a couple of critical lines. If you look at what your code generates for fuses:
Configuration Fuses:
   Word  1: 3FC2   HS NOWDT PUT MCLR NOPROTECT NOCPD BROWNOUT NOCLKOUT IESO FCMEN
   Word  2: 1FFF   NOWRT NOVCAP PLL STVREN BORV19 NOLPBOR NODEBUG NOLVP
Versus what I posted (with your compiler):
   Word  1: 1F82   HS NOWDT PUT NOMCLR NOPROTECT NOCPD BROWNOUT NOCLKOUT IESO NOFCMEN
   Word  2: 1EFF   NOWRT NOVCAP PLL_SW STVREN BORV19 NOLPBOR NODEBUG NOLVP
You have turned the PLL back on. This will almost certainly prevent the clock from starting, since the internal start-up circuit tests that it is seeing a reasonable clock output before changing away from the internal oscillator. With the PLL enabled, this will not be the case...
I have deliberately set this code up so it will not start if the crystal is not running. You have also removed this.
So made some modification and recompiled the code..
Page 2 of 2
