Hardware SPI
Goto page Previous  1, 2
PostPosted: Mon Sep 11, 2017 7:46 am     Reply with quote
Which PIC are you using ?
The HW SPI shows terrible waveform, which may indicate the SPI internal peripheral has been damaged ASSUMING the SW SPI picture is using the SAME I/O pins.
Without any reference I have to assume each division is 1 volt, so SPI highs re 3.++ volts ?
Also SPI bus speed is not given, but for test purposes, I'd go very slow, say 100KHz, or lower, the datatsheet of the device should say. By going slow, you can see the waveform better.
As well, send a known data stream, say '0x5A', something that you can decode visually easily, and of course connect to CS or SS as a sync.
PostPosted: Tue Sep 12, 2017 1:12 am     Reply with quote
Also, how is the PIC supplied?. What smoothing have you got adjacent to the PIC?.
Both wave-forms have horrible noise spikes on the 0v level. I think the scope sample rate is much too slow for the hardware SPI. I think the pulses shown are actually each 8bit bursts, and if they look bad massively under-sampled like this, I hate to think how bad the wave-forms really are...
Atarek
PostPosted: Tue Sep 12, 2017 3:51 am     Reply with quote
I connected the SPI to a SPI bus analyser in the osculloscope, and here are the results,
Knowing that;
D0 : DO
D1 : SCK
D2 : CS
soft spi during mfrc522 communication
https://drive.google.com/open?id=0By2rhMw0TAvNazV3c25zaFN4YVU
hard spi during mfrc522 communication
https://drive.google.com/open?id=0By2rhMw0TAvNcGNFbXAzVFdDZ0E
0x5A test hardware
https://drive.google.com/open?id=0By2rhMw0TAvNSEdvRmNZWEx5c2c
0x5A test software
https://drive.google.com/open?id=0By2rhMw0TAvNSEdDemdpOUFRZ28
from the result above i came up with 2 conclusions,
1- That the DO pin of Hardware SPI is the DI pin in the software SPI,
2- the spi bus analyzer return these result (in hardware SPI) if the sample is on falling edge, and if i change it to rising edge it does not matter, (in software SPI it does not matter)
Regards,
Atarek
PostPosted: Tue Sep 12, 2017 5:32 am     Reply with quote
I can't help any further without knowing which PIC you're using and your 'test' program.
Page 2 of 2
