Write to EEPROM
Goto page Previous  1, 2
PostPosted: Sun Jul 16, 2017 9:15 am     Reply with quote
Ttelmah wrote:
...or an FRAM chip).
FRAMs can wear out too - I speak from experience. I think that the failures were partly due to being written so often and partly due to a fault with the memory itself. We changed to a different manufacturer and the problem went away.
MRAM is another option that is supposedly immune (or almost immune) to wearing out.
PostPosted: Sun Jul 16, 2017 2:46 pm     Reply with quote
Write_float_eeprom, uses write_eeprom.
Understand, write_eeprom, is the 'core' function provided by the compiler, to write one byte to the EEPROM. Any data type larger than a byte has to be transferred using multiple write_eeprom calls. The write_float_eeprom command uses four write_eeprom calls to transfer the float to the EEPROM (since a float is four bytes...).
Newguy, I'd say you had faulty FRAM's. Can happen.
Page 2 of 2
