Motor soft limits not behaving
Goto page Previous  1, 2
rovtech
PostPosted: Mon Feb 20, 2017 12:52 pm     Reply with quote
Yes, #28 wires. there is very little voltage drop for the few hundred mA drawn by the motors. The wires would have to be pretty heavy to avoid voltage drop from the battery to the end of the arm (over 4ft) so the surge current has to come from the capacitor.
Each section has its own PCB, capacitor, 5v power supply, and PIC. The arm has Base section, upper arm section, forearm section, wrist section, and the gripper section with gripper, camera, lights, lasers. The power and I2C wires are daisy chained through each section so the total capacitance is the sum of the distributed capacitance. I was using 500uF per board but am ordering 4700uF which will fit the space on the board.
Exceeding the sense input on the L298 was not the problem. The sense voltage is always positive because of the H bridge and was going a bit high. I reduced the sense resistors from 2.2ohms to 0.5ohms which actually made the problem worse because it allowed more surge current.
I changed the software a bit to avoid slamming into reverse. The relevant parts are (in appropriate places and same for the forearm):
// global variables
    short arm_dir = 1;          // shows motor direction UP
    short arm_run = 0;          // arm is running
// stop if the arm has reached limits
   if (arm_posn>down_limit)          // if lower range limit exceeded
     while (arm_posn>(down_limit-2))     // move off limit
      move_up();
      arm_posn=read_adc();
     stop_arm();                         // stop
     at_arm_limit = 1;                   // set flag in status
   if (arm_posn<up_limit)          // if upper range limit exceeded
     while (arm_posn<up_limit+2)         // move off limit
      move_down();
     stop_arm();                         // stop
// function 'move_up' moves the arm up
void move_up (void)
   if (!arm_dir&&arm_run)
    output_low (PIN_C3);            // coast to a stop
    delay_ms(250);
  output_low (PIN_C6);
  output_high (PIN_C4);             // Set direction UP
  output_high (PIN_C3);             // enable L298
  arm_run = 1;
  arm_dir = 1;
  delay_ms(50);
// function 'move_down' moves the arm down
void move_down (void)
   if (arm_dir&&arm_run)
    delay_ms(250);
  output_high (PIN_C6);
  output_low (PIN_C4);              // Set direction DOWN
  arm_run = 1;
  arm_dir = 0;
  delay_ms(50);
// function 'stop_arm' stops the arm motors
void stop_arm  (void)
  output_low (PIN_C3);             // disable L298
  arm_run = 0;
PostPosted: Mon Feb 20, 2017 1:07 pm     Reply with quote
Be aware of the limitations of capacitors. Get ones with the lowest ESR you can find, and then parallel these with a smaller capacitor with good HF performance (ceramic or polyester typically). Problem is that electrolytic capacitors have poor high frequency performance. You will get better ESR performance from 2*2200uF, in parallel, rather than 1*4700uF. Generally larger capacitors in the same volume have worse ESR figures (just like high capacity batteries, where they sacrifice thickness on the electrodes to get the extra capacity). If you put an HF signal into a large electrolytic capacitor, it behaves like it has several hundred ohms of series resistance, while the same capacitor at a few kHz, may have an ESR only a tiny fraction of an ohm. Look for designs sold as 'extreme performance' (Vishay), Oscon (Sanyo) etc..
Page 2 of 2
