pwm and normal output on same pin for 16f628a
Goto page Previous  1, 2
PostPosted: Mon Mar 14, 2016 8:03 am     Reply with quote
Look at the code I pointed to.
You can't have the PWM in your main code. It needs to be done by a timer (tick) interrupt, if your main code is going to be able to do anything without interfering with the PWM.
baris_akinci
PostPosted: Mon Mar 21, 2016 2:05 pm     Reply with quote
With your advice, I tried to generate pwm by using timer1. Please check the following. Actually, this code works well in Proteus but in real, this does not work. I mean I can not control the pic and I just see LED flash once, then nothing!!
In order to be seen more clear, I deleted codes, typed sub-program instead.
 #include <16F628A.h>
#FUSES INTRC_IO, NOWDT, NOPUT, NOMCLR, NOBROWNOUT, NOLVP
#use fast_io(a)
#use fast_io(b)
#use delay(internal=4000000) // dahili osilatör ayarları
#use rs232(baud=2400,xmit=PIN_B2,rcv=PIN_B1,ERRORS)  // RF haberleşme ayarları
#priority  rda,ext,timer1       // rda yani haberleşme kesmesi önceliği, harici kesme ikinci öncelikte
#define LED1 pin_a0
#define LED2 pin_a1
#define LED3 pin_a2
#define LED4 pin_a3
#define KONTROL pin_b5
char c[10];  // senkronizasyon kontrolü dizini
char kapat[3];  // acma kapama dizini
int counter=1;   // acma kapama değişkeni
int durum=0;   // senkronizasyon sağlandımı değişkeni
int index = 0; // senkronizasyon sağlandımı dizini
int inc=0;  // simulasyon dallanma değişkeni
int red_duty=63;
int Intcount=0;
#int_rda
void RDA_isr(void)
           // rda sub-program
#int_timer1
void timer_pwm_isr(void)
     set_timer1(65400);
   if (Intcount < 255)
      if (Intcount == red_duty)
         output_low(LED1); output_low(LED2);output_low(LED3);output_low(LED4);
   else if(Intcount == 255)
      Intcount = 0;
      output_high(LED1); output_high(LED2);output_high(LED3);output_high(LED4);
    Intcount++;
#INT_EXT
void  EXT_isr(void)   // harici buton ile simulasyon değişimi yapılması fonksiyonu
              // ext sub-program
void sim1() {
                      // simulation 1 sub-program
void sim2() {
                     //   simulation 2 sub-program
void sim3() {
                       //  simulation 3 sub-program
void sim4() {
                      // simulation 4 sub-program
void sim5() {
                      // simulation 5 sub-program
 disable_interrupts(int_timer1);
 enable_interrupts(int_rda);   // rda kesmesi aktif ediliyor
 enable_interrupts(INT_EXT);   // harici kesme aktif ediliyor
 enable_interrupts(GLOBAL);    // rda kesmesinin geleceği bildiriliyor
   set_timer1(65400);
 set_tris_a(0b00010000);
 set_tris_b(0b00000011);
                      if(inc==1) {
                                      while(inc==1) {sim1();}
                     else if(inc==2) {
                                      while (inc==2){sim2();}
                     else if(inc==3) {
                                      while (inc==3){sim3();}
                     else if(inc==4) {
                                      while (inc==4){sim4();}
                     else if(inc==5) {
                                         while(inc==5) {
                                                        enable_interrupts(GLOBAL); }
                     else if(inc==6) inc=1;
                     else if(inc==0) inc=5;
                     else if(inc==15) { disable_interrupts(INT_TIMER1);
                                             output_low(LED1);output_low(LED2);output_low(LED3);output_low(LED4);
                     else inc=inc;
Page 2 of 2
