Soft UART Max Speed ?
Goto page Previous  1, 2
PostPosted: Tue Aug 25, 2015 11:14 am     Reply with quote
I'd suggest the 12F1572.
Cheap (0.43). Assuming you are running at 5v?. If not the LF variant. Loads of peripherals (3*CCP, 1*UART, loads of timers, DAC, Comparator etc.), and draws less power than your current chip!...
The 12F1822/40, is more expensive.
soonc
PostPosted: Tue Aug 25, 2015 10:55 pm     Reply with quote
alan wrote:
use microchip tools to locate depending on what you want.
Both the links below gives 4 part numbers for a 8 pin device with UART
http://www.microchip.com/maps/microcontroller.aspx
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=1005#
Regards
I should visit that site more often.
CCS compiler allows me to build a project for PIC12F1572 but it does not compile at all. !
PostPosted: Wed Aug 26, 2015 4:30 am     Reply with quote
There are some setup problems on early compilers for this chip, but most are easy to fix.
Try something really basic like:
#include <12F1572.h>
#device ADC=10
#FUSES NOMCLR, INTRC_IO, STVREN, NOLVP, NODEBUG, WDT_SW, BROWNOUT_SW
#use delay(internal=2MHz)
#use rs232(baud=9600,parity=N,UART1,bits=8,stream=PORT1,ERRORS)
      output_toggle(PIN_A0); //Test to prove chip is running
and tell us what happens.
soonc
Change of plans
PostPosted: Wed Aug 26, 2015 4:57 am     Reply with quote
If I change plans and use the PIC16LF1823 it allows me to make this a slave I2C and connect it to the existing I2C bus and free up two pins on Chip 2 which means I may yet get rid of a port expander chip !
It also has built in hardware debugging capability which may be needed to get the I2C working.
Price is only a few cents more. Current draw should be a little less also.
Thanks everyone for all the help.
soonc
OK
PostPosted: Wed Aug 26, 2015 5:03 am     Reply with quote
#device ADC=10
Thanks that compiles.
I used the PIC Wizard in the IDE to setup a project and it could not find the include, and it did not generate any #FUSES statements.
I'm still waiting for CCS tech support to fix the Break Point issue on the PIC24. They acknowledged that they could reproduce the issue.
PostPosted: Wed Aug 26, 2015 5:06 am     Reply with quote
Yes, going I2C, with hardware sounds a very good option. Smile
Looks like you have a good idea now of a neat way of doing this. Long term a much better approach.
My opinion of the Wizard unfortunately is not suitable for public release.....
Page 2 of 2
