i2c Slave and RS232 printf
Goto page Previous  1, 2
Linuxbuilders
PostPosted: Tue Aug 18, 2015 3:00 am     Reply with quote
this seem to be working well, I had a look at the ex_slave.c example and it shows up state 1 as an address which is confusing a little because the manual says this:
If 0x00 or 0x80 is returned, an i2C_read( ) needs to be performed to read the I2C address that was
sent (it will match the address configured by #USE I2C so this value can be ignored)
Any light on it? The other thing is that somehow I am unable to use c = i2c_read(); just once and reload the data into a buffer, it is unstable when I do that, now sure why.
void ssp_interupt(VOID)
   byte c;
   state = i2c_isr_state ();
   IF (state <= 0x80) // send data here
      switch (state)
         case 0x80:
            i2c_read(2);
         case 0:
            c = i2c_read();
            i2cbuffer[0] = c;
            IF (c == 0xA0)
               process_i2c = 1;
               process_i2c = 0;
         case 1:
            c = i2c_read();
            i2cbuffer[1] = c;
         case 2:
            c = i2c_read();
            i2cbuffer[2] = c;
         case 3:
            c = i2c_read();
            i2cbuffer[3] = c;
         case 4:
            c = i2c_read();
            i2cbuffer[4] = c;
         case 5:
            c = i2c_read();
            i2cbuffer[5] = c;
         case 6:
            c = i2c_read();
            i2cbuffer[6] = c;
         case 7:
            c = i2c_read();
            i2cbuffer[7] = c;
         case 8:
            c = i2c_read();
            i2cbuffer[8] = c;
         case 9:
            c = i2c_read();
            i2cbuffer[9] = c;
         default:
            i2c_read();
   IF (state >= 0x80) // read data from here
      IF (i2cbuffer[0] == 0xA0)
         check_data_to_i2c ();
         i2cdata = read_back;
         i2c_write (i2cdata);
         SSP_locked = 0;
Help "d" others and then you shell receive some help from "d" others.
PostPosted: Tue Aug 18, 2015 3:16 am     Reply with quote
The confusion is on the word 'address'.
There are two addresses in I2C.
The device address.
The register address.
State 0/0x80 returns the device address.
Then the next I2C operation (state 1), is normally used to send the register address.
Linuxbuilders
PostPosted: Tue Aug 18, 2015 3:21 am     Reply with quote
correction:
   int c;
      if (state == 0x80)
         i2c_read(2);
         c = i2c_read();
      switch (state)
         case 0:
            i2cbuffer[0] = c;
            IF (c == 0xA0)
               process_i2c = 1;
               process_i2c = 0;
         case 1:
            i2cbuffer[1] = c;
         case 2:
            i2cbuffer[2] = c;
         case 3:
            i2cbuffer[3] = c;
         case 4:
            i2cbuffer[4] = c;
         case 5:
            i2cbuffer[5] = c;
         case 6:
            i2cbuffer[6] = c;
         case 7:
            i2cbuffer[7] = c;
         case 8:
            i2cbuffer[8] = c;
         case 9:
            i2cbuffer[9] = c;
         default:
         SSP_locked = 0;
PostPosted: Tue Aug 18, 2015 3:27 am     Reply with quote
As a comment, don't use a default in the switch statement.
The way CCS handles switches, is if you have a number of switch values _and no default_, it codes this as a jump table. Simple looking up the address, and jumping to the required routine. As soon as you add a default, it instead behaves like a if statement, and has to manually check every condition.
If I have (say) 20 consecutive values, and then want a default if outside this range, I'd manually test for the value being outside the range, and then call the switch for the range _only_, without the default.
Linuxbuilders
PostPosted: Tue Aug 18, 2015 4:03 am     Reply with quote
thnx, this is actually very handy information.
Page 2 of 2
