ring buffer
Goto page Previous  1, 2
kmp84
PostPosted: Tue Aug 04, 2015 9:41 am     Reply with quote
Ttelmah wrote:
Questions:
How does the code 'know' where the data block ends?.
What has to happen for the different commands?.
There is a big problem with the CRC calculation. As written, it can generate an ETX character. This could be disastrous.
1.How does the code 'know' where the data block ends?.
if(rxBuff[index-1]==etxPC)
2.What has to happen for the different commands?.
This is not complete program!
3.There is a big problem with the CRC calculation. As written, it can generate an ETX character.
With This example crc calc is not perform yet. But what is the problem ?
PostPosted: Tue Aug 04, 2015 10:56 am     Reply with quote
Imagine you have 208 in the sum so far, and then a '1' is sent (49). This will add to 257. This then adds another 1 to the sum (258), for the carry, and takes the low eight bits, and gets 2. ETX. So your CRC sends as ETX. Result everything starts to go wrong....
kmp84
PostPosted: Tue Aug 04, 2015 1:47 pm     Reply with quote
ETX=0xE3;
    if (temp<224)
       checksum=temp;
       checksum=temp-224;
Page 2 of 2
