aaronik19
Posted: Tue Apr 07, 2015 1:13 am |
Hi All,
I am testing to update new alarm in DS1307. The main program is here:
| Code: | #include <program.h>
#include <MAX517.C>
#include <ds1307.C>
#define LCD_RS_PIN PIN_A3
#define LCD_RW_PIN PIN_A2
#define LCD_ENABLE_PIN PIN_A1
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
//GENERAL VARIABLES
int count_tc = 0;
byte alarm_x = 0;
byte alarm_y = 0;
int8 check_alarm(int8 hrs, int8 min, int8 sec);
int8 alarm_list [3] [3] = {
{07, 38, 00},
{07, 40, 45},
{07, 45, 12}
//timeclock variables
int8 sec;
int8 min;
int8 hrs;
int8 day;
int8 month;
int8 yr;
int8 dow;
//timeclock Alarm variables
// alarm at 17:23:00
int8 sec_alarm;
int8 min_alarm;
int8 hrs_alarm;
int8 day_alarm;
int8 month_alarm;
int8 yr_alarm;
int8 dow_alarm;
load_alarm()
hrs_alarm = alarm_list[alarm_y] [alarm_x];
min_alarm = alarm_list[alarm_y] [alarm_x++];
sec_alarm = alarm_list[alarm_y] [alarm_x++];
alarm_x--;
#INT_TIMER1
void TIMER1_isr(void)
count_tc++;
if (count_tc = 10)
if(check_alarm(hrs, min, sec))
printf("Alarm Activated! \%02d:\%02d:\%02d\n", hrs,min,sec);
output_toggle(PIN_D1);
load_alarm();
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //104 ms overflow
EXT_INT_EDGE(L_TO_H);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
ds1307_init();
delay_ms(400);
delay_ms(200);
load_alarm();
output_high(PIN_D1);
printf("Alarm at \%02d:\%02d:\%02d", hrs_alarm,min_alarm,sec_alarm);
while(true)
ds1307_get_date(day,month,yr,dow);
ds1307_get_time(hrs,min,sec);
lcd_gotoxy(0,0);
printf(lcd_putc, "Date: \%02d/\%02d/\%02d\r\n",day,month,yr);
lcd_gotoxy(0,1);
printf(lcd_putc, "Time: \%02d:\%02d:\%02d", hrs,min,sec);
if((hrs == hrs_alarm) &&
(min == min_alarm) &&
(sec == sec_alarm))
return(TRUE);
return(FALSE);
the three alarms are:
| Code: | {07, 38, 00},
{07, 40, 45},
{07, 45, 12} |
I am trying to use 2d array to update the alarm variables and I am testing this update through RS232 communication. for some reason, the first alarm, instead of 07:38:00 it is coming as 07:07:38
Can someone guide me what is the problem? I can't see the issue? I dont know if I am using the complicated method for this! |
Mike Walne
Posted: Tue Apr 07, 2015 1:28 am |
Try changing ALL the values in your alarm array to different numbers.
Then you will be able to tell where your alarm settings are coming from.
As it stands you can't tell which of the three 7's you are reading.
Mike |
Posted: Tue Apr 07, 2015 1:33 am |
Look at what you are loading:
load_alarm()
//Increments alarm_x _after_ loading the value.......
//You need:
load_alarm()
min_alarm = alarm_list[alarm_y] [++alarm_x];
sec_alarm = alarm_list[alarm_y] [++alarm_x];
alarm_x=0;
As another comment, I have to say since the 'hrs', 'mins' & 'secs' are already declared as global, let 'check_alarms' use these directly.
Currently the code has to copy the global variables into temporary values to pass to the check_alarms function, which then uses these. Since this is inside an interrupt handler, 'extra data movement' that is not wanted/needed.... |
aaronik19
Posted: Tue Apr 07, 2015 8:11 am |
thanks Ttelmah for your help it worled perfectly. Continue a more advance process and since I have multiple alarms, I need to load the new alarms once teh current one expires. The code I am using is:
| Code: | load_alarm()
alarm_x=0;
alarm_y++;
the alarms are:
| Code: | int8 alarm_list [3] [3] = {
{7, 38, 00},
{7, 39, 00},
{7, 40, 00}
it goes through 7:38:00 to 7:39:00 and then to 7:40:00 but after 7:40 expires, it does 00:40:07! and not from the beginning. I tried to use if..else statement but the pic hangs. |
alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
Posted: Tue Apr 07, 2015 8:45 am |
You do reset alarm_y = 0 after your 3rd alarm, don't see it in the code.
Regards |
Posted: Tue Apr 07, 2015 8:46 am |
alarm_y++;
if (alarm_y==3)
alarm_y=0;
aaronik19
Posted: Tue Apr 07, 2015 8:47 am |
| dear all, yes as explained, I made that code and the PIC is hanging! |
aaronik19
Posted: Tue Apr 07, 2015 8:51 am |
forgive me! Instead of "==" I made just one "="
Getting tired after long hours working.....
sorry for annoying you. The code worked perfectly! thanks |
