Help with clocking code
Goto page Previous  1, 2
PostPosted: Wed Feb 25, 2015 10:14 am     Reply with quote
You have already solved that:
ADC_CLOCK_DIV_64
That gives Tad = 1.33uSec
ADC_CLOCK_DIV_32, takes the Tad to 0.66uSec, so is too fast at 48MHz.
If you want to include the TAD_MUL delay, the specified acquire time is 6.4uSec if the source is 2.5KR. So TAD_MUL_6 would be the lowest value that could be used (4 would be a little too short).
younder
PostPosted: Wed Feb 25, 2015 2:22 pm     Reply with quote
Where did you get the 6.4uSec with source = 2.5KR? EQUATION 21-3: shows a minimum of 2.45uSec of acquisition time with source = 2.5KR... am I missing something?
Hugo Silva
PostPosted: Wed Feb 25, 2015 3:04 pm     Reply with quote
I'm using figures I was given by Microchip after I had problems with the ADC. The multiplexer internal resistance is higher than specified. However this may only apply to the early revision I was using at the time, since they have not documented it on the release chips.
younder
PostPosted: Mon Mar 02, 2015 5:34 pm     Reply with quote
A few changes in the code... and it's working just fine... Thanks Ttelmah!
union pulse_data_type {
   int8 buffer;
   struct {
      int1 _50;
      int1 _100;
      int1 _200;
      int1 _500;
      int1 _1000;
   } mSec;
 union pulse_data_type pulse=0;
#INT_TIMER1
void timer1()
  static int8 counter_SP[5] = {2,4,8,20,40}; //Counters Setpoint (Value*25ms)
  static int8 i, counter[5] = {2,3,4,5,6}, mask;
  set_timer1(28035 + get_timer1()); //35000 counts = 25mSec
  mask=1;
  for (i=0;i<5;i++)
      counter[i]--;
     if (counter[i]==0)
        counter[i]=counter_SP[i];
        pulse.buffer^=mask;
     mask*=2;
Any suggestion on the Edge code? I tried to set the flag inside the ISR, since I know when the pulse is changing the state... but I had a hard time trying to figure out when and where to reset it...
Hugo Silva
Page 2 of 2
