RS485 between two PIC problem!
Goto page Previous  1, 2, 3  Next
musti463
PostPosted: Sun Aug 24, 2014 11:10 am     Reply with quote
thank you i fix it
M.Emir SADE
musti463
PostPosted: Sun Aug 24, 2014 1:19 pm     Reply with quote
When i use following codes. System working corretly.
MASTER:
char data[9]="12345678";
SLAVE:
char data[12];
But !!! When i use following codes. System working but i see errors. I don't know Is there a limit for sending data length?
MASTER:
char data[64]="mustafaemirsade-mersin-463-1925-1905-galatasaray";
SLAVE:
char data[64];
You can see sorting is wrong. And data[10]-data[25] is empty. Why?
ERRORS:
M.Emir SADE
PostPosted: Sun Aug 24, 2014 1:59 pm     Reply with quote
Look at my original reply.
Look at items 1, and 3.
Realise if these are _not_ done, the receiver, can/will receive garbage, or NULL characters (your \0), when the bus is not driven....
musti463
PostPosted: Sun Aug 24, 2014 2:42 pm     Reply with quote
@Ttelmah
can you give me schematics and values?
M.Emir SADE
PostPosted: Sun Aug 24, 2014 3:26 pm     Reply with quote
sorting ???? I don't see anything in your code that 'sorts' !
Also as MR. T points out you MUST get the RS485 tranceivers properly configured.Consult the datasheet or Google, there are even BOOKS written about the subject !
If you ONLY have one master and one slave you do not need RS485, rather RS232( using a MAX232 chip) will work without any problems.Simple wire them up and you're done. If PICs are on the same bench ,ONE MAX232 will work for both PICs making the wiring even easier.
The other detail is. Is all done under Proteus/ISIS and not real hardware ???
That question needs to be answered fast.
hth
jay
musti463
PostPosted: Sun Aug 24, 2014 5:19 pm     Reply with quote
Firstly proteus hardware and later real hardware
M.Emir SADE
PostPosted: Sun Aug 24, 2014 6:10 pm     Reply with quote
hmm.. Proteus.... Please acknowledge that it is FULL of bugs, errors and faulty DRCs. It is NOT reliable as a 'simulator'. In fact, EVERY 'schematic' presented here will NEVER work in the real world.
Please look at any RS485 transceiver datasheet and reconfigure your 'project' As others have said, your 'schematic' is not correct.
recode/recompile/retest/report back
jay
PostPosted: Sun Aug 24, 2014 6:39 pm     Reply with quote
Post your latest schematic so they can review it.
musti463
PostPosted: Mon Aug 25, 2014 5:46 am     Reply with quote
I found only these schematics:
and my last shematic:
@temtronic i am learning RS485 communication now. i can't use rs232 because i will use 1 master 5 slave, when i learn rs485 communication tottally
M.Emir SADE
asmallri
PostPosted: Mon Aug 25, 2014 7:18 am     Reply with quote
Look at the figure 9 you posted. See that 'A' on the 485 of the transceiver goes to a pull-up resistor on the safe-bias configuration. Your schematic has A going to a pulled down instead.
However - be aware that some vendors label the inverting input as A and others label the non inverting input as A. They are electrically pin-for-pin compatible but use A and B nomenclature differently. You need to ensure the specific 485 transceiver you are using is the same as the one in the application note to ensure your A and the applications A both refer the the same input.
Regards, Andrew
musti463
PostPosted: Mon Aug 25, 2014 8:07 am     Reply with quote
i made a mistake i changed
M.Emir SADE
musti463
PostPosted: Mon Aug 25, 2014 9:42 am     Reply with quote
Can we send directly float values? else we have to use sprintf for float to string and send data by rs485 ?
M.Emir SADE
PostPosted: Mon Aug 25, 2014 10:59 am     Reply with quote
You can send the bytes that comprise float values, and then re-assemble these at the other end.
Easiest way is a union.
This is fine PIC-PIC, but will give difficulties PIC-PC, since the PIC internally stores the values in a different format to the PC. There are routines in the supplied examples that include the conversion (search for IEEE).
musti463
PostPosted: Mon Aug 25, 2014 12:46 pm     Reply with quote
@Ttelmah can you give me some example codes about it
M.Emir SADE
PostPosted: Mon Aug 25, 2014 1:36 pm     Reply with quote
Use the forum's search page. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=42199
Page 2 of 3
