Commands to get Size of a SDCARD
Goto page Previous  1, 2
nabeards
Re: THANK YOU!
PostPosted: Fri Jun 27, 2014 6:40 pm     Reply with quote
neochrome32 wrote:
ok getting some strange resulsts mainly all zero's...
its a problem with my code, and not yet got stuck..
I, too, am in a situation where I'm getting all 0s. What was it that finally made your code start working?
Thanks!
nabeards
asmallri
Re: THANK YOU!
PostPosted: Fri Jun 27, 2014 7:26 pm     Reply with quote
Thanks!
nabeards
A common mistake in hardware implementations is a missing pull-up resistor on DO of the card. This often prevents the card being put into SPI mode and, as a result, the PIC will see a floating SPI bus and not data output from the card.
Another common error is insufficient current to the card, especially during writes (high impedance power source and/or insufficient filtering and bypass capacitance on the cards power supply). This can result in a card's embedded processor resetting and, as a result, being in native mode instead of SPI mode. When the happens the PIC again sees a floating SPI bus and not the expected output from the card.
Regards, Andrew
nabeards
Re: THANK YOU!
PostPosted: Fri Jun 27, 2014 8:08 pm     Reply with quote
Thanks Andrew! I'm actually able to send and receive data just fine to the card, it's just the CID and CSD that seem to be just giving me 0s. I thought it might be something particular with the stack or with the command I'm sending; I am getting the data bit but then just 0s. I tried two different-branded cards, both SDHC.
nabeards
Page 2 of 2
