Using fat.c
Goto page 1, 2  Next
skelzer
Using fat.c
PostPosted: Tue Apr 26, 2016 5:58 am     Reply with quote
Hello there,
Could I get any example using the library fat.c where the SD is written via SPI?(http://www.ccsinfo.com/forum/viewtopic.php?t=53787)
I usually like to take my time reading and experimenting, but this time I'm in a bit of a hurry, so... Embarassed
Thank you very much.
PostPosted: Tue Apr 26, 2016 6:46 am     Reply with quote
well first place to look is in the 'code library' here...
or general search 'SD'...
also
You MUST use a 3 volt( 'L' series) PIC OR proper logic level translation between the 3 volt SD card and a 5 volt PIC. If you don't .it won't work correctly !!
skelzer
PostPosted: Tue Apr 26, 2016 7:43 am     Reply with quote
also
Hey, thanks for the quick reply Smile
I've tried to use the search and won't return any results when I use SD as the keyword. Anyways, thanks for the tip about the code library, found a few threads there that are being really helpful Smile.
And yes, I'm using a 3 volt PIC, I don't want to fry the SD! Smile
The thing is, I won't have any way to test this until thursday, and it's due friday (Don't you guys love when your deadlines are completely ridiculous? I totally do :D ) so I'm trying to put together a code that'll work quick.
Here I'm trying (or failing hard) to create a file called log1.txt, would this work?
         #define MMCSD_PIN_SCL     PIN_B10 //o
         #define MMCSD_PIN_SDI     PIN_B11 //i
         #define MMCSD_PIN_SDO     PIN_B12 //o
         #define MMCSD_PIN_SELECT  PIN_B13 //o
main()
mmcsd_init()
char filename[]="log1.txt";
fat_init();
mk_file(filename);
mmcsd_write_byte(0, filename);
PostPosted: Tue Apr 26, 2016 8:19 am     Reply with quote
Comments in line:
//These need to be declared _before_ you load the mmc library.
main()
    //keep to the C standard and declare variables at the start of sections
    FILE file_stream; //You need a file variable created.
    mmcsd_init(); //semi-colon missing
    fat_init();
    mk_file(filename);
    //Now you need to open the file....
    //mmcsd_write_byte(0, filename);
    //No. You write to the open [u]file[/u].
    fatopen(filename,"w", file_stream);
    fatputc('\0',file_stream); //This now writes the 0 byte to the file
    fatclose(file_stream); //then you must close the file
    while (TRUE)
Also general comment you must have the pull-up resistors on some of the SD lines. required to ensure it wakes in the right mode, and also recommended to speed the rising edges.
skelzer
PostPosted: Tue Apr 26, 2016 8:36 am     Reply with quote
Ttelmah wrote:
Comments in line:
main()
    fat_init();
    mk_file(filename);
    while (TRUE)
First of all, thank you very much Ttelmah for being so thorough, this helps a lot, as I don't even have the IDE in the PC I'm using today, so I'm using notepad.
I think I have the basics down by now, will work on it tomorrow and hope everything works fine on Thursday (Praying to the gods of compilation now...)
PostPosted: Tue Apr 26, 2016 9:24 am     Reply with quote
One warning. In the code library you will find three threads, including an SDHC modification, and a couple of fixes for faults in the standard SD driver. There is then an 'accrued' version at the start of the forum as a sticky (from electr0dave). Use this.
This fixes all the current bugs with the MMC driver and also gives support for cards over 2GB.
skelzer
PostPosted: Wed Apr 27, 2016 2:02 am     Reply with quote
Roger.
I could get my hands on the IDE earlier than I expected, tried this:
#include <main.h>
#include <mmcsd.h>
#include <fat.c>
      FILE file_stream;
      mmcsd_init();
      fat_init();
      mk_file(filename);
      fatopen(filename,"w",file_stream);
But gives me a few errors:
*** Error 90 "main.c" Line 17(27,28): Attempt to create a pointer to a constant
*** Error 51 "main.c" Line 18(20,31): A numeric expression must appear here
*** Error 51 "main.c" Line 19(16,27): A numeric expression must appear here
Line 17 is fatopen.
Before I forget, my compiler version is 5.045.
skelzer
PostPosted: Wed Apr 27, 2016 2:08 am     Reply with quote
Fixed:
Added the line
#device PASS_STRINGS=IN_RAM
after the #include <33EP512GP504.h>
and changed the declaration of
      FILE file_stream;
to
      FILE *file_stream;
PostPosted: Wed Apr 27, 2016 2:15 am     Reply with quote
Needs to be added.
Then all the references to file_stream, need & (except in the declaration).
PostPosted: Wed Apr 27, 2016 2:31 am     Reply with quote
Whoa.
Your way of 'fixing' it, means you can be writing to an undeclared area of memory. It'll compile, but won't necessarily work.....
Problem is that:
File *file_stream;
Means that 'file_stream' is now a pointer, but doesn't actually declare any where for it to point 'to'.....
Declaring 'FILE file_stream;' declares the actual variable.
If you want to save typing '&', do this:
FILE actual_stream;
FILE *file_stream=&actual_stream;
Then you can use 'file_stream' as a pointer to 'actual_stream', and it will be pointing to legitimate memory....
skelzer
PostPosted: Wed Apr 27, 2016 2:34 am     Reply with quote
Ttelmah wrote:
Whoa.
Problem is that:
File *file_stream;
FILE actual_stream;
It's 9 AM in the morning, I've had way too little coffee and I'm absolutely blaming it on that.
Thanks Ttelmah, you're being a real life-saver.
PostPosted: Wed Apr 27, 2016 3:06 am     Reply with quote
I'm sorry I left the '&' off when typing my stuff. Smile
We all do it.
skelzer
PostPosted: Fri May 06, 2016 2:43 am     Reply with quote
Hello again Smile, things got really busy and I couldn't work on this project, but I'm back on it :D.
It seems the program keeps looping at
fat_init();
If I comment this line here:
#use FIXED_IO( B_outputs=PIN_B2, PIN_B10, PIN_B11, PIN_B15)
It won't get stuck on that part, but will keep returning -1 (Error I guess).
Any idea why could this be? (I'll be uploading the signals I got with my logic analyzer in a few minutes)
PostPosted: Fri May 06, 2016 3:51 am     Reply with quote
Have you actually tested that you have the sector read and write working on the device?.
Fat_init, calls the mmcsd_init. This does the speed changes to switch the device up to the faster SPI clock. The way it is written, is fractionally silly. Instead of exiting if mmcsd_init errors, it ploughs on and tries to read, to get the sector size, and data layout. So if the init has failed, it can get into a really problematical state.
I'd be checking that you have the mmcsd driver working properly before trying to get fat working.
skelzer
PostPosted: Fri May 06, 2016 4:01 am     Reply with quote
I'd swear you comment everytime I'm editing my post... Wink
Will check it out as soon as I'm done uploading the signals I got with the logic analyzer.
Goto page 1, 2  Next
Page 1 of 2
