IO Ports as Input
Goto page 1, 2  Next
Sterngleiter
IO Ports as Input
PostPosted: Thu Jul 31, 2014 2:11 pm     Reply with quote
I have the following problem:
I would like to count for something.
The port is controlled by a pushbutton.
The pushbutton is 10cm away from port. When I turn off the voltage, not actuated pushbutton is counted. that should not be.
When I touch the cable between button and pic its counted without push button but not ever.
the Code is :
#include <main.h>
int test;
while(true)
   if(input(pin_a1)==1)
      while(input(pin_a1)==1);
      ++test;
I can find nothing on the internet is no solution. I can not check with oscilloscope.
Thanks for HELP
alan
PostPosted: Thu Jul 31, 2014 2:15 pm     Reply with quote
How is your PB connected? Is it pulled low or high? (Show ASCII diagram if possible).
Also do a search for debouncing of your PB.
Regards
Sterngleiter
PostPosted: Thu Jul 31, 2014 2:40 pm     Reply with quote
It's pulled low.
Debounced over
While(input(pin_a1)==1);
Mike Walne
PostPosted: Thu Jul 31, 2014 2:49 pm     Reply with quote
Two questions:-
1) How do you know what the value of your variable 'test' is?
2) How fast do you think it might count?
Mike
Sterngleiter
PostPosted: Thu Jul 31, 2014 2:54 pm     Reply with quote
I forgot to mention that I still have lcd display.
When i turn off the Power only then counted alone without pushing Button
Mike Walne
PostPosted: Thu Jul 31, 2014 3:08 pm     Reply with quote
So please give us short, complete and compilable code which shows the problem you are having.
Mike
Sterngleiter
PostPosted: Thu Jul 31, 2014 3:23 pm     Reply with quote
Is Not difficult Code. It is Running. You Must only insert printf (lcd...)
My Problem is why counted when i turn off the power.
I also use a output instead of the variable.
I can see it. Is a Short Time High.
#include <main.h>
int test;
while(true)
      Output_high(pin_b0);
Mike Walne
PostPosted: Thu Jul 31, 2014 3:30 pm     Reply with quote
You're the one wanting help.
There must be something you're not telling us.
If you refuse to provide a complete picture, I'm out.
Bye.
Mike
Sterngleiter
PostPosted: Thu Jul 31, 2014 3:44 pm     Reply with quote
It is really original Code that i have. I'm writing from telephone therefore I can not copy from compiler "pcwhd 5.0 ". When i touch the cable from switch during turn off the power without pushing then is the Output High for a Short Time but Not ever. why should not say everything I. I have this Problem with more pic controller. oddly always the same error.
PostPosted: Thu Jul 31, 2014 5:25 pm     Reply with quote
It sounds like the input is acting as an antenna and picking up strong EMI or local AC ( 50 or 60 Hz). That's one of the problems using an active high as opposed to active low input signal.
You should have some low value capacitor on the input to 'filter' the 'noise'.
Without seeing a schematic or picture of your project it is difficult to tell what the real problem is.
Perhaps you can change the 'logic' to active low( grounding the input = 'true') and see what happens ?
hth
jay
Sterngleiter
PostPosted: Fri Aug 01, 2014 1:24 am     Reply with quote
I have also tried the other way around.
always the same result.
as I said it only occurs when off.
I would like to also add the wiring diagram but I do not know how
PostPosted: Fri Aug 01, 2014 2:08 am     Reply with quote
You put the image on a website (either your own, or a 'free picture hosting' site), and post the link to it here.
alan
PostPosted: Fri Aug 01, 2014 2:48 am     Reply with quote
Edit OOPS Embarassed
Or just use ASCII
          VCC
          |_|   _|_
PIN  ------|----   ----------|
                           __|__
                            ___
                             _
Regards
PostPosted: Fri Aug 01, 2014 3:02 am     Reply with quote
But if using ASCII, remember to use the 'code' buttons round it, so the formatting is preserved. Otherwise it is not legible....
Sterngleiter
PostPosted: Fri Aug 01, 2014 5:30 am     Reply with quote
it's just like having drawn alan.
I do not understand what you mean Ttelmah.
why is the line of push buttons like a antenna.
I am looking for solution set several months.
please help me.
I can not even imagine that I'm the only one with this problem-
Goto page 1, 2  Next
Page 1 of 2
